1991 Toyota Celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 02:54 PM   #1 (permalink)
jenngennoy
Guest
Posts: n/a
View jenngennoy's Photo Gallery
1991 Toyota Celica
My gas pedal is really stiff what can i do to fix it?? is it a big problem?
Old 06-27-2005, 06:47 PM   #2 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
Re: 1991 Toyota Celica
On Mon, 27 Jun 2005 14:54:40 -0400, jenngennoy wrote:
[color=blue]
> My gas pedal is really stiff what can i do to fix it?? is it a big problem?[/color]
As Deep Throat might say, "Follow the cable..."
Locate the throttle cable and get a GOOD spray lubricant. Spray the
lubricant into the cable, from both ends, if you can, and also any
linkages, etc. This should free things up.
Old 06-27-2005, 08:05 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"jenngennoy" <jenn@gennoy.com> wrote in message
news:66ada4a4dbed26cf8eb86731c399f291@localhost.talkaboutautos.com...[color=blue]
> problem?
>[/color]
Remove the hose from the throttle body, spray the inside of the throttle
body with aerosol EFI/carb cleaner, wipe out, open the throttle plate,
repeat.
Ray O
correct the return address punctuation to reply
Old 06-27-2005, 08:28 PM   #4 (permalink)
JeB
Guest
Posts: n/a
View JeB's Photo Gallery
On Mon, 27 Jun 2005 14:54:40 -0400, "jenngennoy" <jenn@gennoy.com>
wrote:
[color=blue]
also make sure your carpeting / floor mats aren'tt interfering with
the gas pedal.
Old 06-27-2005, 10:40 PM   #5 (permalink)
TeGGeR®
Guest
Posts: n/a
View TeGGeR®'s Photo Gallery
news:66ada4a4dbed26cf8eb86731c399f291@localhost.talkaboutautos.com:
[color=blue]
> problem?
>[/color]
What exactly do you mean by "stiff"?
Is it really hard to get popped loose after you let go of the pedal, but
then moves freely thereafter? Or is it hard to move at *any* time?
First one is a dirty throttle body, second is a binding cable.
TeGGeR®
BB code is Off
Smilies are Off
[IMG] code is Off
