Replacing timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2005, 01:36 AM   #1 (permalink)
Michael & Julie-Anne Kunde
Guest
Posts: n/a
View Michael & Julie-Anne Kunde's Photo Gallery
Hi
I'm hoping someone can help me. I have a 1984 Toyota Corona CS 2.0L (ST141
series) auto. The timing belt has broken. When replacing valve timing belt
where should timing marks be aligned to, both top and bottom pulley. I did
have a manual, but lent it to "friend" who has now "lost" it. Any
assistance would be greatly appreciated (also saving me from having to pay a
mechanic to fix this).
Cheers
Julie
Old 06-28-2005, 05:33 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Replacing timing belt
"Michael & Julie-Anne Kunde" <spachookie@bigpond.com> wrote in message
news:Dl5we.8375$oJ.847@news-server.bigpond.net.au...[color=blue]
> Hi
> (ST141 series) auto. The timing belt has broken. When replacing valve
> timing belt where should timing marks be aligned to, both top and bottom
> pulley. I did have a manual, but lent it to "friend" who has now "lost"
> it. Any assistance would be greatly appreciated (also saving me from
> having to pay a mechanic to fix this).
> Cheers
> Julie
>[/color]
Set #1 cylinder to top dead center compression by turning the crankshaft
clockwise. The mark on the bottom pulley should align with the mark.
Rotate the camshaft(s) so that it is also aligned with the mark, it should
also be pointing straight up. The new belt should have marks to help you
align the pulleys.
Ray O
correct the return address punctuation to reply
Old 06-28-2005, 11:10 PM   #3 (permalink)
jjjsan
Guest
Posts: n/a
View jjjsan's Photo Gallery
Buy a service manual, Haynes (ok, generic) or Toyota (Best).
Some public libary carry service manuals.
Also check ebay for used manuals.
Not sure what the setup is for the corona, but you may need some special
tools, like air compressor/impact wrench to get the bolt off the
crankshaft pulley.
While you are replaceing timing belt, consider the other items in that
area the maybe worn and require replacing, like water pump, thermostat,
hoses, crank seals, etc.
Old 06-28-2005, 11:16 PM   #4 (permalink)
Guest
Posts: n/a
Thanx Ray - will try & set how it goes
Julie
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in message
news:jMidnXy7gIKhW1zfRVn-gQ@comcast.com...[color=blue]
> news:Dl5we.8375$oJ.847@news-server.bigpond.net.au...[color=green]
>> Hi
>> Cheers
>> Julie
>>[/color]
> align the pulleys.
> Ray O
>[/color]
Old 06-28-2005, 11:57 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:eoowe.9160$oJ.1990@news-server.bigpond.net.au...[color=blue]
> Julie
>[/color]
You're welcome and good luck!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
