Re: Engine replaced, leaking oil, dented oil pan (was: How much istoo much oil?) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2005, 10:58 AM   #1 (permalink)
Tercel Owner
Guest
Posts: n/a
View Tercel Owner's Photo Gallery
jjjsan wrote:[color=blue]
> Is the oil leaking from the rusted spot or from the gasket? If oil
> is leaking from oil pan due to a rusted hole, the entire pan can be
> replaced or try some epoxy like J-B weld on the leak.[/color]
The oil is leaking from front main seal, rear main seal, and oil
draining plug.
[color=blue]
> If leaking due to warped pan, entire pan may need to be replaced.
> There is normally copper or alumin washer on oil pan plug that need
> to be replaced. Looks like you need to find the source of the other
> leaks. Check valve cover for oil leak, there is a gasket that is on
> the cover and a spark plug grommet that can cause oil to weep down
> the engine and hit the exhast manifold and cause smoking.[/color]
As far as I can see, it's leaking from the 3 locations above.
[color=blue]
> I don't think a leak from oil pan can cause smoking, unless it is
> leaking on the exhaust manifold or pipe.[/color]
It doesn't smell like burning oil, just hot oil. After driving, I
smell it everywhere, in my hair, in my clothes, and just breathing.
And it causes some serious coughing for a long time. On windy days,
it's not so bad (I have all windows open). And when I drive mostly on
the highway, with only small amounts of urban stop-and-go driving
(e.g. at traffic lights), it's not so bad. But it's bad enough that
if I use the vents rather than opening the window, it reeks even at
highway speeds.
[color=blue]
> Check the distributor for oil leaks, there is o-ring on the shaft
> that require periodic replacing. Real seal replacement can be
> costly. There are some engine additive and high mileage oil that is
> suppose to recondition the seals.[/color]
I attend my car-care course tonight, so I'll print out your message
and ask about where these things are when it's up on a hoist.
About these oils that recondition the seals, are they required
forever? Do they have any drawback? Also, is this reasonable quality
for a newly installed used engine, with new rear main seals? That's
where most of the seepage is coming from. I want to be reasonable
about the job that was done, and I'm concerned that this is perhaps
not what one would expect. But perhaps it is. Leaking from new
rear main seals is confusing, though.
Old 06-30-2005, 01:05 AM   #2 (permalink)
jjjsan
Guest
Posts: n/a
View jjjsan's Photo Gallery
Re: Re: Engine replaced, leaking oil, dented oil pan (was: How much
Oil pan plug leaks, need to change out washer.
Check if washer is there, sometimes, they are lost or left off during oil
change.
check with dealer.
Front crankshaft seal can be changed out. You'll need to remove all of the
exterior belts, remove the timing belt, crank pulley. If you need to
change out the timing belt, have it done then.
You may also have a oil leak from the camshaft seal. which is drips down
in same location as front main seal. Have it changed also when changing
timing belt.
Rear main seal, will cost will be steep. maybe over $500 for labor. Get
some quotes.
If you smell the oil, it must be dripping on a hot engine part, like
exhast manifold, exhast pipe, cat conveter.
Have a close look around the front and rear of engine, after a long
drive.
BB code is Off
Smilies are Off
[IMG] code is Off
