The right rear window will not operate from the driver's side switch
assembly or the up down switch on the right rear door. Other windows all
operate.
Before I rip the door panel off, is there a fuse for this window operation?
If so location please.
Thank you,
Seamus J. Wilson
"sligo" <sligo@cox.net> wrote in message
news:BlAxe.15656$ro.12602@fed1read02...[color=blue]
> operate.
> operation?
> Thank you,
> Seamus J. Wilson
>[/color]
It is not the fuse or relay if the other windows operate properly.
When only 1 window does not work, it is either the master switch, the switch
on the door, the motor, or the harness. The only other possibility is the
regulator is binding. Those are the only causes.
You will need a factory service manual or wiring diagram to diagnose the
switches and harness.
The switch at the inoperable door will have 5 terminals. Continuity between
the terminals will vary as you move the switch in the up, down, and off
positions. The master switch will have a bunch of terminals and diagnosing
is basically the same way.
If either of the switches gets exposed to moisture often, like driving in
the rain with the window open or spilled drinks, the internal contacts can
get corroded.
The motor will have a power connector with 2 terminals. Apply 12 volts
power and ground to the terminals and the motor should operate. Reverse the
connections and the motor should operate in the opposite direction.
To see if the regulator itself is binding, you will have to remove the motor
and see if the regulator moves.
Ray O
correct the return address punctuation to reply
One would be well advise to operate ALL switches on occasion, to
keep the contacts clean. It is most often the switch least used
that is first to go because of arking across corroded contacts.
mike hunt
Ray O wrote:[color=blue]
> news:BlAxe.15656$ro.12602@fed1read02...[color=green]
> > operate.
> > operation?
> > Thank you,
> > Seamus J. Wilson
> >[/color]
> get corroded.
> Ray O
> correct the return address punctuation to reply[/color]
Thank you all for the information.
Best,
Seamus J.
<SlimPickens@mailcity.com> wrote in message
news:42C6EF32.4B80087D@mailcity.com...[color=blue]
> mike hunt
> Ray O wrote:[color=green]
> > news:BlAxe.15656$ro.12602@fed1read02...[color=darkred]
> > > assembly or the up down switch on the right rear door. Other windows[/color][/color][/color]
all[color=blue][color=green][color=darkred]
> > > operate.
> > > operation?
> > > Thank you,
> > > Seamus J. Wilson
> > >[/color]
> > When only 1 window does not work, it is either the master switch, the[/color][/color]
switch[color=blue][color=green]
> > on the door, the motor, or the harness. The only other possibility is[/color][/color]
the[color=blue][color=green]
> > The switch at the inoperable door will have 5 terminals. Continuity[/color][/color]
between[color=blue][color=green]
> > positions. The master switch will have a bunch of terminals and[/color][/color]
diagnosing[color=blue][color=green]
> > If either of the switches gets exposed to moisture often, like driving[/color][/color]
in[color=blue][color=green]
> > the rain with the window open or spilled drinks, the internal contacts[/color][/color]
can[color=blue][color=green]
> > get corroded.
> > power and ground to the terminals and the motor should operate. Reverse[/color][/color]
> > To see if the regulator itself is binding, you will have to remove the[/color][/color]
motor[color=blue][color=green]
> > Ray O
> > correct the return address punctuation to reply[/color][/color]
On Sat, 02 Jul 2005 14:32:26 -0500, Ray O wrote:
[color=blue]
>> all operate.
>> operation?
>> Thank you,
>> Seamus J. Wilson
>>[/color]
> switch on the door, the motor, or the harness. The only other possibility
> is the regulator is binding. Those are the only causes.
> between the terminals will vary as you move the switch in the up, down,
> and off positions. The master switch will have a bunch of terminals and
> diagnosing is basically the same way.
> get corroded.
> the connections and the motor should operate in the opposite direction.
> motor and see if the regulator moves.[/color]
On both my Celica and my Supra, corroded contacts were the culprit.
I pulled the switches from the door panel, sanded them down using an emery
board and a small fingernail file, and then put a LIGHT cotaing of solder
on them (CAREFUL!!! Don't let the solder run ANYWHERE! I found out the
hard way that, for some reason, there is a LOT of current running through
this switch! Enough to 'weld' the screwdriver I was using for testing to
the contacts!)
"hachiroku" <ae86@Trueno.GTS> wrote in message
news:pan.2005.07.03.03.04.38.136514@Trueno.GTS...[color=blue]
>[color=green]
>>> all operate.
>>> operation?
>>> Thank you,
>>> Seamus J. Wilson
>>>[/color]
>> possibility
>> can
>> get corroded.
> On both my Celica and my Supra, corroded contacts were the culprit.[/color]
It seems to happen to smokers more often because they drive with the window
cracked open and strays drops of water blow in.
[color=blue]
> the contacts!)[/color]
LOL! Reminds me of Woody on Cheers talking about finding out the hard way
that "flammable" and inflammable" are the same thing.
Lots of current runs through the window switch because the current doesn't
pass through a relay.
Ray O
On Sat, 02 Jul 2005 23:43:25 -0500, Ray O wrote:
[color=blue]
> news:pan.2005.07.03.03.04.38.136514@Trueno.GTS...[color=green]
>>[color=darkred]
>>>> all operate.
>>>> operation?
>>>> Thank you,
>>>> Seamus J. Wilson
>>> possibility
>>> the switches and harness.
>>> and diagnosing is basically the same way.
>>> in the rain with the window open or spilled drinks, the internal
>>> contacts can
>>> get corroded.
>>> Reverse the connections and the motor should operate in the opposite
>>> direction.
> window cracked open and strays drops of water blow in.[/color]
Two for two there, Ray! Although I have only owned the car for three
years, and I don't think any of the other owners were smokers.
However, when you rip the AC out, I guess you gotta open the window, even
when it's raining!
[color=blue]
>[color=green]
>> emery board and a small fingernail file, and then put a LIGHT cotaing of
>> solder on them (CAREFUL!!! Don't let the solder run ANYWHERE! I found
>> out the hard way that, for some reason, there is a LOT of current
>> running through this switch! Enough to 'weld' the screwdriver I was
>> using for testing to the contacts!)[/color]
> pass through a relay.[/color]
Yeah, I wonder why. I also noticed something else weird about the system,
but I can't remember what it was. Something to do with the switch logic,
and the way it reverses the current.
news:pan.2005.07.04.02.54.51.570238@Trueno.GTS...[color=blue]
>[color=green]
>> news:pan.2005.07.03.03.04.38.136514@Trueno.GTS...[color=darkred]
>>>>> all operate.
>>>>> operation?
>>>>> Thank you,
>>>>> Seamus J. Wilson
>>>> possibility
>>>> contacts can
>>>> get corroded.
>>>> direction.
> when it's raining!
>[/color]
Those lexan vent shades that attach to the forward edge of the door frame
seem like a good idea.
>>[color=darkred]
>> doesn't
>[/color]
It is probably easier to use heavier wires that are direct-wired than using
relays. If either the master or one of the door switches is bad, then the
window will not work, almost as if they are wired in series.
Ray O
