Toyota Pickup 1981 electrical problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2005, 08:35 PM   #1 (permalink)
jaimeworking
Guest
Posts: n/a
View jaimeworking's Photo Gallery
hi all,
so, now i’m totally confused, changed everything in my electrical
system and my alternator still doesn’t work, it works when i go have
it checked but doesn’t work in my truck. what could be wrong? thanks
all.
warm regards,
jp
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-Pickup-1981-electrical-problem-ftopict129763.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=632389[/url]
Old 07-19-2005, 09:23 PM   #2 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
Re: Toyota Pickup 1981 electrical problem
On Tue, 19 Jul 2005 20:35:55 -0400, jaimeworking wrote:
[color=blue]
> hi all,
> so, now i’m totally confused, changed everything in my electrical system
> and my alternator still doesn’t work, it works when i go have it checked
> but doesn’t work in my truck. what could be wrong? thanks all.
> warm regards,
> jp[/color]
You say everything; have you checked the fusible links?
Old 07-20-2005, 02:35 AM   #3 (permalink)
jaimeworking
Guest
Posts: n/a
Re: Re: Toyota Pickup 1981 electrical problem
"" wrote:[color=blue]
>[color=green]
> > hi all,
> > so, now i’m totally confused, changed everything in my[/color]
> electrical system[color=green]
> > and my alternator still doesn’t work, it works when i go[/color]
> have it checked[color=green]
> > but doesn’t work in my truck. what could be wrong? thanks[/color]
> all.[color=green]
> > warm regards,
> > jp[/color]
> You say everything; have you checked the fusible links?[/color]
which are the fusible links?
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=632629[/url]
Old 07-20-2005, 09:14 PM   #4 (permalink)
hachiroku
Guest
Posts: n/a
On Wed, 20 Jul 2005 02:35:55 -0400, jaimeworking wrote:
[color=blue]
> "" wrote:[color=green]
> >[color=darkred]
> > > hi all,
> > electrical system[color=darkred]
> > have it checked[color=darkred]
> > all.[color=darkred]
> > > warm regards,
> > > jp[/color]
> which are the fusible links?[/color]
On an '81, they are probably near the positive battery terminal; they look
like giant fuse holders. There is either a real big fuse, or a piece of
wire inside them. I know that's where they were on my '78 Corolla and back
then the truck were a step or two behind the cars. I think my '80 Corolla
had these type, also.
Alternately, look in the fuse block under the hood. There is usuall a
piece of pink wire and a piece of pastel yellow (lovely colours, eh?)
under the cover. These are the fusible links.
You can get fusible link wire at any parts store. But if you're blowing
fusible links, you may well have another problem.
Old 07-21-2005, 11:36 PM   #5 (permalink)
jaimeworking
Guest
Posts: n/a
Re: Re: Re: Toyota Pickup 1981 electrical problem
>[color=green]
> > "" wrote:[color=darkred]
> > > > hi all,
> > > electrical system
> > > > and my alternator still doesn’t work, it works when i[/color][/color]
> go[color=green][color=darkred]
> > > have it checked
> > > > but doesn’t work in my truck. what could be wrong?[/color][/color]
> thanks[color=green][color=darkred]
> > > all.
> > > > warm regards,
> > > > jp
> terminal; they look
> piece of
> Corolla and back
> '80 Corolla
> usuall a
> colours, eh?)
> you're blowing
> fusible links, you may well have another problem.[/color]
checked out the fusible links and they look good. what can cause the
alternator not to run?
thanks all, you have helped me thru some real problems.
jp
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=633275[/url]
Old 07-22-2005, 08:26 PM   #6 (permalink)
hachiroku
Guest
Posts: n/a
On Thu, 21 Jul 2005 23:36:25 -0400, jaimeworking wrote:
[color=blue]
> >[color=darkred]
> > > > > hi all,
> > > > electrical system
> > go[color=darkred]
> > > > have it checked
> > thanks[color=darkred]
> > > > all.
> > > > > warm regards,
> > > > > jp
> > look
> > back
> > Corolla
> jp[/color]
Let's see, 1981...the only other thing I can think of (that is, me; others
may have a different clue...) is that the voltage regulator may be off the
alternator on this model and is blown. You say it teats (teats??? What the
hell am I thinking!!?? Must have been thinking about that REAL cute one
that came in with the baby this PM...Whoa! Lucky kid! He'll never go
hungry!!! Let's try, TESTS!) good; are they testing voltage regulation? If
the regulator is on board, then the alternator will run at a steady 12 VDC
under test. If the VR is not on the alternator, then the output will vary
from 9VDC to 18-20 VDC depending on how fast the rotator is turning, and
the regulator will clamp it to 12 (actually, 13.8 VDC.) Some of the older
models had the VR mouted elsewhere in the engine compartment, and, as I
had mentioned, sometimes the trucks were a step or two behind the cars, so
it is very well possible this does not have an on-board VR. Or, worse, the
regulator also contains the rectifier curcuits, and is expecting a raw AC
output. If the alternator you have has a built-in regulator, and is
sending 13.8VDC to an off-board rectifer/VR that is expecting AC voltage,
that is a REAL good reason why the circuit is not working!
As an aside, I was in Brattleboro VT this weekend and saw a 1976 E/5 Long
Bed in IMMACULATE shape. It had 36,000 on it; belonged to the guy's Dad
who parked it for the better part of 30 years in a garage...Nice truck!
Good Luck!
BB code is Off
Smilies are Off
[IMG] code is Off
