Tercel jacking points question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2005, 10:19 AM   #1 (permalink)
joshua.hassol@volpe.dot.gov
Guest
Posts: n/a
View joshua.hassol@volpe.dot.gov's Photo Gallery
Hello -
I have a '96 Tercel DX coupe. I want to do some brake work on the car.
I'll work on one wheel at a time. If I use my scissors jack to lift
the car, where can I position a jack stand? The scissor jack will be
in the jacking point, so I can't put the stand there. Can I put the
stand right next to the jacking point, along the same pinch weld? Or
should I position it somewhere else?
Thanks.
Old 07-20-2005, 10:48 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Tercel jacking points question
<joshua.hassol@volpe.dot.gov> wrote in message
news:1121869155.988718.316600@g44g2000cwa.googlegroups.com...[color=blue]
> Hello -
> Thanks.
>[/color]
I would not put the jack stand next to the jacking point along the pinch
weld unless the stand has a slot to accommodate the pinch weld. If you
lower the car so that the pinch weld itself rests on the jack stand, you
will bend the pinched metal. The jack that comes with the car has a slot in
it so that the weight of the car rests on the flat metal on either side of
the pinch weld.
In front, good spots for jack stands are where the suspension, engine,
and/or transmission are bolted to the undercarriage.
In the rear, good spots for jack stands are where the suspension is
attached. If the car has a solid beam between the rear wheels, the beam is
a good spot.
Ray O
correct the return address punctuation to reply
Old 07-20-2005, 11:14 AM   #3 (permalink)
Guest
Posts: n/a
Ray O wrote:[color=blue]
> the pinch weld.
> a good spot.
> Ray O
> correct the return address punctuation to reply[/color]
Thanks for the advice. The car does have a solid beam between the
wheels. My only remaining question is, with one wheel lifted off the
ground using a scissor jack, is it safe to go under the car to position
the jack stands? I'll chock the wheels, of course, and put on the
parking brake and put the car in gear.
Old 07-20-2005, 11:24 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:1121872454.978983.171650@z14g2000cwz.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
>> in
>> of
>> the pinch weld.
>> is
>> a good spot.
>> Ray O
>[/color]
It is never safe to crawl under a vehicle supported only by a jack. That
said, I will reach under a vehicle making sure that only my arm is under the
vehicle to place a jack stand. I'm not sure that you can lift a vehicle
enough with a scissors jack to actually get jack stands underneath, unless
they are very low stands.
Ray O
Old 07-20-2005, 02:36 PM   #5 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
"joshua.hassol" wrote:[color=blue]
>Hello -
>I have a ’96 Tercel DX coupe. I want to do some brake work on
>the car.
> I’ll work on one wheel at a time. If I use my scissors jack to
>lift
>in the jacking point, so I can’t put the stand there. Can I put
>the
>Thanks.[/color]
Place a jack stand under the axle or control arm for the wheel you are
working on and then jack it done some so it is being held in in two
places for added safety as they will not both fail at once.
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-Tercel-jacking-points-ftopict129844.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=632825[/url]
Old 07-20-2005, 02:37 PM   #6 (permalink)
SnoMan
Guest
Posts: n/a
Re: Re: Tercel jacking points question
"Ray O" wrote:[color=blue]
>news:1121872454.978983.171650@z14g2000cwz.googlegroups.com...[color=green]
>> Ray O wrote:[color=darkred]
>>> I would not put the jack stand next to the jacking point[/color][/color]
>along the pinch[color=green][color=darkred]
>>> weld unless the stand has a slot to accommodate the pinch[/color][/color]
>weld. If you[color=green][color=darkred]
>>> lower the car so that the pinch weld itself rests on the jack[/color][/color]
>stand, you[color=green][color=darkred]
>>> will bend the pinched metal. The jack that comes with the[/color][/color]
>car has a slot[color=green][color=darkred]
>>> in
>>> it so that the weight of the car rests on the flat metal on[/color][/color]
>either side[color=green][color=darkred]
>>> of
>>> the pinch weld.
>>> In front, good spots for jack stands are where the[/color][/color]
>suspension, engine,[color=green][color=darkred]
>>> In the rear, good spots for jack stands are where the[/color][/color]
>suspension is[color=green][color=darkred]
>>> attached. If the car has a solid beam between the rear[/color][/color]
>wheels, the beam[color=green][color=darkred]
>>> is
>>> a good spot.
>>> Ray O
>> Thanks for the advice. The car does have a solid beam between[/color]
>the[color=green]
>> wheels. My only remaining question is, with one wheel lifted off[/color]
>the[color=green]
>> ground using a scissor jack, is it safe to go under the car to[/color]
>position[color=green]
>> the jack stands? I’ll chock the wheels, of course, and put[/color]
>on the[color=green]
>>[/color]
>That
>under the
>vehicle to place a jack stand. I’m not sure that you can lift a
>vehicle
>unless
>they are very low stands.[/color]
Thats way I would put it under the control arm. My son has a Tercel
and we just did a brake job on it the way.
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=632892[/url]
Old 07-20-2005, 03:14 PM   #7 (permalink)
Guest
Posts: n/a
SnoMan wrote:[color=blue]
> "joshua.hassol" wrote:[color=green]
> >Hello -
> >the car.
> >lift
> >the
> >Thanks.[/color]
>I didn't realize the control arm was strong enough to support that much weight.[/color]
Old 07-20-2005, 03:27 PM   #8 (permalink)
Guest
Posts: n/a
> Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=632825[/url][/color]
weight.
Old 07-20-2005, 07:35 PM   #9 (permalink)
SnoMan
Guest
Posts: n/a
>I didn’t realize the control arm was strong enough to support
The lower control arm holds the weight of the arm and road stress. It
is quite strong.
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=633036[/url]
Old 07-23-2005, 06:18 AM   #10 (permalink)
Johnnyboy
Guest
Posts: n/a
View Johnnyboy's Photo Gallery
I always lay the wheel I have taken off under the edge of the car as well as
jack stands. Better to wreck a rim than have the car fall on me.
John
"hachiroku" <ae86@Trueno.GTS> wrote in message
news:pan.2005.07.21.01.15.27.929247@Trueno.GTS...[color=blue]
> On Wed, 20 Jul 2005 07:19:16 -0700, joshua.hassol wrote:
>[color=green]
>> Hello -
>> the car, where can I position a jack stand? The scissor jack will be in
>> the jacking point, so I can't put the stand there. Can I put the stand
>> right next to the jacking point, along the same pinch weld? Or should I
>> Thanks.[/color]
> Unless I am stuck somewhere, I use a hydraulic jack and jack stands. I got
> my jack a the Evil Wal-Mart for $39, it has a safety bar that goes into a
> hole under the jacking arm. I jack the car up, and then use jack stands
> that have a wide enough top to accomodate the 'frame rails', underneath
> the car. These are stmpings in the steel floor pan the look like frame
> rails. I jack the car, place the jack stand, insert the safety bar and
> then lower the car until it contact the jack stand, and then raise the
> jack to make sure all of the weight is neither on the jack or the stand.
> And block the wheel opposite from the corner of the car you are jacking,
> too. Yeah, I'm paranoid, but even a light car weighs well over a half a
> ton.
> I did my brakes and my exhaust on a '95 Tercel this way.[/color]
Old 07-23-2005, 02:49 PM   #11 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Sat, 23 Jul 2005 10:18:24 +0000, Johnnyboy wrote:
[color=blue]
> John[/color]
Ja, dot too...!
[color=blue]
> news:pan.2005.07.21.01.15.27.929247@Trueno.GTS...[color=green]
>>[color=darkred]
>>> Hello -
>>> Thanks.[/color]
>> ton.
>> I did my brakes and my exhaust on a '95 Tercel this way.[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
