I have a 2000 Sienna that just turned over 60,000 miles. The owners
manual says I should replace the spark plugs. I can do the 3 facing the
front but how do you get to the 2 facing back? I figured out how to do this.
Remove the PCV hose on the left (passenger side) under the intake. Move any
wire out of the way. Use two 3' extensions. Long small hands will help, -:).
Do it slowly and be careful not to knock loose any connectors or hoses
accidentally.
"Andy Arhelger" <aarhelger@nospam.com> wrote in message
news:42decc92_3@news3.prserv.net...[color=blue]
>I have a 2000 Sienna that just turned over 60,000 miles. The owners manual
>says I should replace the spark plugs. I can do the 3 facing the front but
> Andy Arhelger[/color]
Two 3' extensions? And do you reach them from the top, I suppose and not
from underneath?
Andy Arhelger
XYZ ABC wrote:[color=blue]
> accidentally.
>[/color]
Yep, two 3' extensions. One is too short for the plug hole. One 6' is too
long to get into the hole back there. You have to make the connection back
there after inserting one first.
Yes, you reach back there from the top of the engine, under the intake. You
can get the left one from the left and the right two from the right (through
the center of the half circle of the intake).
news:42dff6c7_2@news3.prserv.net...[color=blue]
> from underneath?
> Andy Arhelger
> XYZ ABC wrote:[color=green]
>> any wire out of the way. Use two 3' extensions. Long small hands will
>> help, -:). Do it slowly and be careful not to knock loose any connectors
>> or hoses accidentally.
>>[/color]
>[/color]
On Fri, 22 Jul 2005 01:11:22 GMT, "XYZ ABC" <XYZ@abc.com> wrote:[color=blue]
>news:42dff6c7_2@news3.prserv.net...[color=green]
>> XYZ ABC wrote:[/color][/color]
[color=blue][color=green][color=darkred]
>>> or hoses accidentally.[/color]
>> from underneath?[/color]
>the center of the half circle of the intake).[/color]
Something has been /really/ bothering me every time I read this...
Are you two really talking about a three FOOT (36 inch) socket
extension when you use the abbreviation 3' ? Or are you mis-typing a
three INCH extension, which should be abbreviated as 3" ? ;-P
Ignoring the fact that most people don't have arms long enough to
work with a three foot extension (let alone two coupled end to end)
without a helper to guide the socket end as you crank the handle...
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Bruce L. Bergman <blPYTHONbergman@earthlink.invalid> wrote:
[color=blue]
>On Fri, 22 Jul 2005 01:11:22 GMT, "XYZ ABC" <XYZ@abc.com> wrote:[color=green]
>>news:42dff6c7_2@news3.prserv.net...[color=darkred]
> --<< Bruce >>--[/color]
Same here!...I can't picture someone using 'that' on a car!...but
then it was used several times the same way...gee...
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
>>>> Remove the PCV hose on the left (passenger side) under the intake. Move[color=blue][color=green][color=darkred]
>>>> connectors
>>You
>>(through
>[/color]
Changed the sparkplugs last night. Wasn't too tough. The 2 in the back
on the drivers side were not too bad. The one on the passengers side is
harder. Using 2 3" extensions worked good. I (my son actually) ended up
having to reach around the intake manifold from both sides one hand on
each side with my chin on almost on the windshield.
In article <42e63ece_2@news3.prserv.net>,
Andy Arhelger <aarhelger@nospam.com> wrote:
[color=blue]
> Thanks for the tips.
Dbu_^ wrote:[color=blue]
>[color=green]
> Which model year Sienna you working on?[/color]
