Re: 2000 Corolla seatbelt light malfunction - How expensive?
<tedneeley@yahoo.com> wrote in message
news:1122048483.588518.27240@g47g2000cwa.googlegroups.com...[color=blue]
> [email]tedneeley@yahoo.com[/email] wrote:[color=green]
>> My 2000 corolla has a problem with seatbelt signal light. I observed it
>> two days ago. Even if I buckle-up (as always), the blinker is not going
>> away. It's a bit annoying. If I pull the belt a bit, the blinker goes
>> away but if I release it, it's back on.
>> I assume there's a short circuit somewhere.
>> How expensive is this to fix if I take it to the dealer?
>> Thanks in advance.[/color]
> OP here again. I'm still looking for a ballpark figure on how much I
> can expect to spend on this.
> Is this something a handy person can do himself?
> Thanks.
>[/color]
If you're handy, shine a light into the receptacle and use a thin probe or
pick to see if there are any foreign objects in there. Coins are the most
common culprit, drinks are next. You could remove the receptacle, turn it
upside down and shake it to see if anything comes out. If not, then replace
it.
Ray O
correct the return address punctuation to reply
