Re: 96 Avalon air condtioning
"Ray Nichols" <trayn@bresnan.net> wrote in message
news:fbGdnaPPXpLxg37fRVn-og@bresnan.com...[color=blue]
>I was wondering if anyone had a problem like this: Had my Avalon 7 years,
>and from the first, the air won't stay on...it cools while the light on the
>button is on, but when it flashes it turns off. I turn it back on, it might
>work a few seconds, or a few days, then goes back to staying on whenever it
>wants to. I have had the condenser and compressor replaced over the years,
>had a module that the mechanic called a "radio" temporarily put in (didn't
>work). Any ideas? It's getting more and more regular, but the mechanic said
>it might have to totally die before he could diagnose, since it is so
>sporatic. Help??[/color]
The flashing AC light is the clue. When the AC light flashes, the system
has detected a difference between the compressor and engine RPM. This can
happen when water splashes on the pulleys, if the belt it worn, glazed, or
the wrong profile. You could have a pulley that is not spinning freely,
something could be hanging up the compressor or clutch, or the RPM sensor
circuit could have a problem. I'd start with the belt and then check the
RPM sensor circuit.
Ray O
correct the return address punctuation to reply
