94 Corolla: lights on dash board and shift went off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2005, 02:36 AM   #1 (permalink)
Jason
Guest
Posts: n/a
View Jason's Photo Gallery
All the lights on the dash board (except the left and right "turn
light") couldn't be turned on, also the lights on the shift. I took
out the dash board and checked the lights on the back of the circuit
board. They looked good to me. Should I check the fuse? If so, which
fuse to check? Is it the fuse named "guage"?
Thanks.
Jason
Old 07-24-2005, 02:11 PM   #2 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
Re: 94 Corolla: lights on dash board and shift went off
[email]jiangcomm@gmail.com[/email] (Jason) wrote:
[color=blue]
>Thanks.
>Jason[/color]
You're putting us on, right?!
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
Old 07-24-2005, 04:06 PM   #3 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
On Sun, 24 Jul 2005 18:11:04 +0000, Gord Beaman wrote:
[color=blue]
>[color=green]
>>All the lights on the dash board (except the left and right "turn light")
>>couldn't be turned on, also the lights on the shift. I took out the dash
>>board and checked the lights on the back of the circuit board. They
>>looked good to me. Should I check the fuse? If so, which fuse to check?
>>Thanks.
>>Jason[/color]
> You're putting us on, right?![/color]
Actually, the fuse marked guage, I think, controls the guages themselves
(I don't remember...in all the time I've been 'modifying' Corolla wiring
for stereos, custom lights, alarms, wtc, it's the only one I HAVEN'T blown!)
My bet is if it isn't a fuse, which would be very good for you, it is a
connector that has come loose behind the cluster. Since you have the
cluster out already, look for a loose wire in a connector.
I suppose I should have done this in my Mom's car two years ago, but
removing the dash cluster is such a PAIN!
Old 07-24-2005, 04:28 PM   #4 (permalink)
Gord Beaman
Guest
Posts: n/a
hachiroku <ae86@Trueno.GTS> wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>>Thanks.
>>>Jason[/color]
>removing the dash cluster is such a PAIN![/color]
That's what I meant...I can't imagine taking that dash apart
rather than just looking for a fuse...
-Gord.
Old 07-24-2005, 07:07 PM   #5 (permalink)
Gord Beaman
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote:
snip
[color=blue]
>Or before checking the fuse, turning the dash light dimmer knob.
>Here's the order I would have used,
>1) Turn the dimmer knob
>2) Check lighting and gauge fuses
>3) Check the dimmer knob rheostat
>4) Check for loose connections at the rheostat
>5) Check the cluster[/color]
Yep...agree...
-Gord.
BB code is Off
Smilies are Off
[IMG] code is Off
