How To Open A Stuck Corolla Trunk - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 17 Old 07-29-2005, 08:31 PM
GWN
Guest
Posts: n/a
Quoted: Post(s)
The lock on my 94 Corolla trunk is not working. The key does not turn
and it doesn't open. For the last 6 months, I've been using the
internal trunk release.
Now the trunk release stops working. Any idea of how to get the trunk
open and replace the lock? Even if I take out the deck by the rear
window, I don't think I can reach the lock from inside.
Thanks,
Art
post #2 of 17 Old 07-29-2005, 08:45 PM
Gord Beaman
Guest
Posts: n/a
Quoted: Post(s)
Re: How To Open A Stuck Corolla Trunk
GWN <artwong@rogers.com> wrote:
[color=blue]
>Thanks,
> Art[/color]
You sure you're not trying to use the 'valet key'?...it's not
supposed to unlock your trunk, just work the ignition...got
another key?, try it.
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
post #3 of 17 Old 07-29-2005, 10:34 PM
GWN
Guest
Posts: n/a
Quoted: Post(s)
On this model, the ignition key opens the trunk too. When it was
working I used the same key all the time for ignition and trunk. I
think you are referring to a special valet key which I think operates
the car but not the trunk or glove compartment.
Thanks,
Art
On Sat, 30 Jul 2005 01:45:25 GMT, Gord Beaman <gord@islandtelecom.com>
wrote:
[color=blue]
>[color=green]
>>Thanks,
>> Art[/color]
>another key?, try it.[/color]
post #4 of 17 Old 07-29-2005, 11:04 PM
Truckdude
Guest
Posts: n/a
Quoted: Post(s)
"GWN" <artwong@rogers.com> wrote in message
news:k4tle1pmli7hrkfmsg71g301evn7ohu4s0@4ax.com...[color=blue]
>[/color]
I agree with you. I also think he was referring to the valet key only
working in the ignition when he used the words "valet key" and "just work
the ignition". ;-)
[color=blue]
> Thanks,
> Art
> wrote:
>[color=green]
>>[color=darkred]
>>>Thanks,
>>> Art[/color]
>[/color]
post #5 of 17 Old 07-30-2005, 02:30 AM
Bruce L. Bergman
Guest
Posts: n/a
Quoted: Post(s)
On Fri, 29 Jul 2005 23:34:47 -0400, GWN <artwong@rogers.com> wrote:
[color=blue]
>the car but not the trunk or glove compartment.[/color]
If your car has the Valet Lock feature on the trunk, and you still
have the "master key" you stick it in the trunk lock and turn (right,
I think) to open the trunk. But if you turn it to the left it will go
90 degrees and click-stop, and allow you to remove the key. That
might be where your lock is set (accidentally) now.
In the "valet lock" position, the 'valet key' will not work in the
trunk lock to open it, and the inside release lever is also locked
out. Now you can safely give the Valet parking attendant only the
Valet Key - not on a ring with your house keys or any other keys. You
keep the Master Key in your pocket.
This is to keep the stuff you have stored in the trunk safely away
from the possibly sticky fingers of the valet.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
post #6 of 17 Old 07-30-2005, 06:57 AM
Scott in Florida
Guest
Posts: n/a
Quoted: Post(s)
On Sat, 30 Jul 2005 07:30:40 GMT, Bruce L. Bergman
<blPYTHONbergman@earthlink.invalid> wrote:
[color=blue]
>[color=green]
>from the possibly sticky fingers of the valet.[/color]
You mean someone wouldn't trust Ed 'kooky' Burns?....
Say it ain't so!
btw they re ran an episode of 77 Sunset Strip on one of the old TV
channels the other weekend. I never realized how much of a luster
Kooky was....LOL
[color=blue]
> --<< Bruce >>--[/color]
Scott in Florida
post #7 of 17 Old 07-30-2005, 08:06 AM
Hachiroku
Guest
Posts: n/a
Quoted: Post(s)
On Fri, 29 Jul 2005 21:31:21 -0400, GWN wrote:
[color=blue]
> Thanks,
> Art[/color]
Fold down one of the rear seats (available) and take a screwdriver and
slip the latch open.
post #8 of 17 Old 07-30-2005, 08:12 AM
GWN
Guest
Posts: n/a
Quoted: Post(s)
I wish it were so easy. The Corolla is a sedan and the rear seats
don't fold down.
Thanks,
Art
On Sat, 30 Jul 2005 13:06:32 GMT, Hachiroku <Trueno@ae86.gts> wrote:
[color=blue]
>[color=green]
>> Thanks,
>> Art[/color]
>slip the latch open.[/color]
post #9 of 17 Old 07-30-2005, 09:05 AM
N/A bites
Tercel GTS's Avatar
Quoted: 79 Post(s)
Remove the seats then. Pull up the bottom part first then unbolt the top part. Do not curse the car while you are going through this, it gave you 6 months to fix the first problem.
雄のハヤブサ
Tercel GTS is offline
post #10 of 17 Old 07-30-2005, 09:44 AM
ma_twain
Guest
Posts: n/a
Quoted: Post(s)
You could drill out the trunk lock as a last ditch method.
You would then have to replace it. Any car thieves or former car thieves
have a better idea?
Not that it helps you now, but you did have six months to fix the
problem right while the remote release was working. . . Like the
commercial said, "You can pay me now, or you can pay me later". Only
later it is going to cost a lot more.
GWN wrote:
[color=blue]
> don't fold down.
> Thanks,
> Art
>[color=green]
>>[color=darkred]
>>>Thanks,
>>> Art
>>>[/color]
>>[/color]
>[/color]
post #11 of 17 Old 07-30-2005, 12:38 PM
Hachiroku
Guest
Posts: n/a
Quoted: Post(s)
On Sat, 30 Jul 2005 09:12:39 -0400, GWN wrote:
[color=blue]
> don't fold down.[/color]
Rats. They ALL do now. Can you remove the rear seat? All you do is give it
a firm tug and it will pop out. Pull from the bottom. >[color=blue]
> Thanks,
> Art
>[color=green]
>>[color=darkred]
>>> Thanks,
>>> Art[/color]
>>slip the latch open.[/color][/color]
post #12 of 17 Old 07-30-2005, 12:39 PM
Hachiroku
Guest
Posts: n/a
Quoted: Post(s)
On Sat, 30 Jul 2005 10:05:30 -0400, Tercel GTS wrote:
[color=blue]
> 6 months to fix the first problem.[/color]
BTW, where are the pix? I wanna see this Tercel GTS.
I have started looking for a Paseo to Hot Rod...
post #13 of 17 Old 07-31-2005, 12:27 AM
mmward@webtv.net
Guest
Posts: n/a
Quoted: Post(s)
There are many auto repair or body shops throughout the USA that
perhaps could help you, some of them are reputable, I bet you could find
one. What are you waiting for? Devine intervention? If I worry about
it long enough it will stop? There may even be a Toyota dealership that
could figure it out in a heartbeat. The thing isn't working the way
it's supposed to, get it fixed. Rip out the seats? Jesusgod, DIY is
one thing, but it's a lock. Get it fixed.
post #14 of 17 Old 07-31-2005, 04:49 AM
Lou@GoForIt.net
Guest
Posts: n/a
Quoted: Post(s)
Hachiroku wrote:
[color=blue]
>[color=green]
> > Thanks,
> > Art[/color]
The seats in my 2003 Corolla fold down by pulling a release that is INSIDE
the trunk:-((
Lou
post #15 of 17 Old 07-31-2005, 07:31 AM
hachiroku
Guest
Posts: n/a
Quoted: Post(s)
On Sun, 31 Jul 2005 05:49:00 -0400, Lou wrote:
[color=blue]
> Hachiroku wrote:
>[color=green]
>>[color=darkred]
>> > Thanks,
>> > Art[/color]
> the trunk:-(([/color]
Yeah, I have noticed they have begun doing that. The seat releases used to
be on the tops of the seat backs.
[color=blue]
> Lou[/color]
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
Back
