What is the normal battery current leakage when a car is off? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2005, 09:26 AM   #1 (permalink)
MM
Guest
Posts: n/a
View MM's Photo Gallery
Hi all,
I am measuring 20 mA in my Camry'89, 12 mA through the main fuse and 8 mA
through the alternator's one. In this model there is a small fuse box with 3
fuses attached directly to the positive clamp on the battery...
There is no alarm in this car, the only thing that might be drawing some
current would be radio in the standby mode, which I probably should try
disconnecting completely... That would explain 12 mA...
The reason I am asking is because the car did not start after sitting not
used for 3 weeks. I calculated that in 3 weeks it should have lost about 10
Ah at 20 mA drain. I then recharged the battery with a charger, but since
then it doesn't seem to keep the charge anymore... I am going to replace the
battery anyways, but would like to know if I have a leakage problem as
well...
Thanks,
/Mikhail
Old 08-10-2005, 02:15 PM   #2 (permalink)
Gordon Slishman
Guest
Posts: n/a
View Gordon Slishman's Photo Gallery
Re: What is the normal battery current leakage when a car is off?
We experienced similar Interstate battery weakness after garaging our
'95 Camry for six weeks. The Toyota service manager said it's "normal"
and advised battery disconnection next time. The '00 Camry original
battery seemed ok.
-Gordon
"MM" <mbmsv@yahoo.com> wrote in message
news:3ludf9F14gf4tU1@individual.net...[color=blue]
> Hi all,
> 3
> 10
> the
> well...
> Thanks,
> /Mikhail
>[/color]
Old 08-10-2005, 02:55 PM   #3 (permalink)
JM
Guest
Posts: n/a
View JM's Photo Gallery
"Gordon Slishman" <slishman@hotmail.com> wrote in message
news:LurKe.5278$0E5.3431@fe05.lga...[color=blue]
> battery seemed ok.
> -Gordon
> news:3ludf9F14gf4tU1@individual.net...[color=green]
>> Hi all,
>> with 3
>> 10
>> the
>> well...
>> Thanks,
>> /Mikhail
>>[/color]
>[/color]
Hi,
I have a 1995 CAMRY had it from new.
Its only about 6 months ago I changed the original battery.
Over 9 years in use was unbelievable.
Mine would still turn the car over after 5 weeks in garage while I was away
on holidays
and that was with the alarm armed.
Yet it died overnight and would not turn car over.
One cell SG was virtually uncharged when I checked it out.
It never recovered even with long external charging.
Just my 2 cents.
Johnny UK.
Old 08-10-2005, 05:32 PM   #4 (permalink)
Jason James
Guest
Posts: n/a
View Jason James's Photo Gallery
> Hi all,
> through the alternator's one. In this model there is a small fuse box with[/color]
3[color=blue]
> used for 3 weeks. I calculated that in 3 weeks it should have lost about[/color]
10[color=blue]
> then it doesn't seem to keep the charge anymore... I am going to replace[/color]
the[color=blue]
> well...
> Thanks,
> /Mikhail[/color]
20 ma is normal. Anything over 60ma should be investigated. The main current
consumer when the car is off is the clock which today usually lives in the
radio.
Jason
Old 08-10-2005, 08:59 PM   #5 (permalink)
Daniel
Guest
Posts: n/a
View Daniel's Photo Gallery
Here's the answer to a question nobody asked, but I've been quite
pleased with this stuff in two vehicles:
[url]http://www.batterystuff.com/productdisplay.html?id=403&c=106[/url]
One is a 1977 Toyota pick up truck that gets driven only rarely - so
that would be the worst possible use for a battery - crank, and crank
to bring fuel up to the carburetor, then relatively short trips, then
sitting again a long time.
The other vehicle is a 1994 Camry driven daily, with headlights on,
generally short trips, hard to keep a full charge, but now always spins
over with gusto.
The fluid doesn't require very much to utilize, so I think I've got
enough left over for several more batteries.
BB code is Off
Smilies are Off
[IMG] code is Off
