Re: Re: Oil Purgatory
"pacde" wrote:[color=blue]
> [quote:c2fdf278c8="SnoMan"][quote:c2fdf278c8="pacde"]I
> recently bought a Toyota Tercel, 98 and brought it in for an
> oil change and some new tires - other than that the car is
> perfect. After the oil change, I took it for a test drive down
> the highway and the next day I took my wife up into the
> mountains - all together about 200 miles. Anyway I loaded fuel
> and went to check the oil and this is what happened:
> First there was no oil cap so all the underside of the hood
> was covered with oil. I checked the oil and wouldnt you know
> it, it was way over full. I checked the receipt and instead of
> adding 2.8 Litres of oil, the service center added 4.5 litres
> of oil. I understand some severe engine damage can result due
> to overfilling - can someone please walk me through the things
> I should look for?[/quote:c2fdf278c8]
> THe only real damge likley is seal damge to front and rear
> main seals. If they were blow out you would know it by now and
> when that happens oil is ususally coming out of breather to
> from foaming up but it take a pretty good over fill to do it.
> Wash everything down good and watch for new leaks, if there
> are none, you are okay then.[/quote:c2fdf278c8]
> You think I should worry about anything like the catalytic
> converter - I heard somewhere that oil can kill it.[/color]
Take a lot of oil to hurt it and in the inside of it, not the outside.
Wash under the hood real good are a power hand car wash and if no new
leaks are found, chalk it up to a story to tell over a cup of coffee
sometime and laugh about it because I am sure you are not laughing
when you first found it. It looks a whole lot worse than it is most of
the time.
