3S-GTE exhaust valve stem seals. How difficult to replace? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2005, 05:39 PM   #1 (permalink)
Sleeker GT Phwoar
Guest
Posts: n/a
View Sleeker GT Phwoar's Photo Gallery
Upon startup, if I'm forced to give it a little more welly than normal,
say upto 4k rpm instead of the more normal 3k rpm until warmed up, to
get into a gap, I notice gey smoke from the exhaust.
A small cloud that clears completley after about 10 seconds.
I'm guessing is oil that is either getting past the piston rings at
startup or the exhaust valve stem seals as it sits overnight, seaps past
and gets burned on startup.
Other possibility is, since I cleaned up the PCV, it is breathing a lot
more oil fumes, as the BOV is showing some spray pattern. i could be
that that is gathering and getting blown through at startup and burning
then. Guess I need to righ up that catch can and see.
Carl Robson
Car PC Build starts again. [url]http://smallr.com/rz[/url]
Homepage: [url]http://www.bouncing-czechs.com[/url]
BB code is Off
Smilies are Off
[IMG] code is Off
