Ok I have a 1990 Toyota Corolla Wagon, not 4 wheel drive or anything, with
the 1.6L Engine, works great, gets great Gas Mileage, and has about
237000Km's on it. For about half the year now when you go to accelerate
Really hard and fast, it studders, not on a specific interval, but very
spaced out, even if you aren't looking for much acceleration, it still
studders,
What could be causing this? The Plugs are good, and the Wires are were
changed not too long ago. Please tell me somthing to check.
Oh yeah, it burns Oil, valve seals, maybe that might be somthing?
"72Capri" <corolla1990@hotmail.com> wrote in message
news:57b2779ca91fed840c0b59c46ecf0f5e@localhost.talkaboutautos.com...[color=blue]
> studders,
> Thanks
> Chris
>[/color]
When you say that the plugs are good, did you pull them and check their
condition? They should be light to medium grayish-brownish in color with no
black or oily deposits on the electrodes.
If you used aftermarket plugs and wires, this can sometimes cause the
condition you're describing. You'll have better luck with OEM plugs and
wires.
Burning oil usually does not cause stutter or misfire unless it's really bad
with clouds of bluish smoke out the tailpipe.
You didn't mention whether you have an automatic or manual transmission. If
automatic, check the condition of the transmission fluid to make sure it is
not burnt - you could be feeling transmission slippage.
Ray O
correct the return address punctuation to reply
On Sat, 13 Aug 2005 12:47:42 -0400, 72Capri wrote:
[color=blue]
> studders,
> Thanks
> Chris[/color]
Well if the plugs were fouled I wouldn't be getting great gas mileage, and
It's a Manual Transmission. thanks though, oh and My father is driving the
same car, just that his is an Automatic, and his works fine, same plugs and
wires, but the plugs are fine, I've checked.
Thanks for the input, Dad and I changed the Distributor Cap, Rotor Button,
Plugs, and wires, and that fixed it, you could see that the Posts in the
Distributor cap was really worn down, and there was Arching happening on
the Rotor Button. So replaced it, took er out for a good spin, and not a
studder, even put it in 5th doing 50km/h going up a hill and accelerated
and it didn't studder!.
