Re: Previa front sunroof leaking
"wilm" <wilm@nospam.ntlworld.com> wrote in message
news:a69c520f6479448afefc07e0804eae27@localhost.talkaboutautos.com...[color=blue]
>I have a 3 year old previa with a leak from the front sunroof (the one
> which just hinges open a couple of inches) I suspect that the sunroof
> drain holes may be blocked. But as the sunroof panel is hinged I can't see
> how to remove and inspect.
> Any advice welcome.
> Thanks[/color]
The Previa hasn't been sold in the U.S. for a while so I don't remember if
the front sunroof is manual or power tilt. If it is manual tilt, then look
at the handle/latch when it is in the up position and release the handle,
tip the glass all the way up, and remove.
Plan B: If you have access to compressed air with a rubber-tipped nozzle,
clean the drain hoses from the bottom up.
Ray O
correct the return address punctuation to reply
