Re: 1990 Celica Sputtering
"cbrown09" <cbrown09@shepherd.edu> wrote in message
news:d144137d099696a3a82108f28db4e309@localhost.talkaboutautos.com...[color=blue]
>a few days ago my 1990 Celica struggled to start up and when it it, it
> sputtered badly. Before this she purred like a kitten. It has 172K
> miles. Now if I accelerate slowly, it runs ok, but if I give it much gas,
> it hesitates and kindof studdors. It has about half the getup it had days
> ago. I changed the plugs and the distributor rotor, checked my wires and
> connections. It improved slightly, but still hestitates noticeably in
> every gear and has little getup. Could it be my timing?
>[/color]
Did problem start after you changed the plugs and rotor and checked the
wires? If so, did you use aftermarket ignition parts? Did you change the
distributor cap and ignition wires?
Check for vacuum leaks and for a crack in the intake hose between the air
flow meter and intake manifold.
Check your ignition timing - make sure the distributor hasn't twisted.
Ray O
correct the return address punctuation to reply
