Highlander Towing Harness Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2005, 10:38 PM   #1 (permalink)
Joey
Guest
Posts: n/a
View Joey's Photo Gallery
Hi all,
I decided to put a hitch on my 2004 Highlander which has the tow prep
package. I went to my Toyota dealership and purchased the wiring
harness which has the trailer flat plug on one end, then a grommet
about half way up and then a black box with wires attached going in
and out and then to a white plug. The white plug has five pins inside
it (male). The part number on the package was 00016-48205-15 and also
has Reese: 57210. Does anyone know where this white plug goes ??? I
assume it's probably in the rear compartment somewhere
but I can't find anything in the service manual. The package also came
with a mounting bracket, some nut washers, cable ties, and a 20 amp mini
fuse. But......no instructions or diagram. :o(
Any help will be greatly appreciated.......THANKS.
J
Old 09-15-2005, 11:49 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Highlander Towing Harness Question
"Joey" <jlancos_nospam@moultriega.com> wrote in message
news:11ikc0nmjgaufe1@corp.supernews.com...[color=blue]
> Hi all,
> package. I went to my Toyota dealership and purchased the wiring harness
> and out and then to a white plug. The white plug has five pins inside it
> (male). The part number on the package was 00016-48205-15 and also has
> Reese: 57210. Does anyone know where this white plug goes ??? I assume
> J[/color]
Try these instructions:
[url]http://www.toyotaparts4u.com/00016482050104HigLander%20Hitch%20Wiring%20Harness.pdf[/url]
If that doesn't work, just google 00016-48205-15 or go to the
[url]www.toyotaparts4u.com[/url] site and search wiring harnesses for your vehicle.
Ray O
correct the return address punctuation to reply
Old 09-16-2005, 04:58 PM   #3 (permalink)
ron
Guest
Posts: n/a
View ron's Photo Gallery
My 02 had the prep package also. The wiring harness was included and
was packaged under the vehicle. There is (on mine) a plastic box
roughly 4-5 inches deep, about 7" wide and maybe 14" long mounted
under the chasis to the bottom of the pan holding the spare tire.
This box is where the plug in to the system electrical is. The box (or
cover as you prefer) has quite a few drainage holes in it. I believe
mine had a cap on it (from vehicle) - I plugged in pigtail (harness)
and mounted it to the bumper. It is the flat 4 connector type with
rubber cover.
I bought the receiver from u-haul, installed just over 125 if I
remember for type III
Curious if 04 is different?
ron
Old 09-16-2005, 05:05 PM   #4 (permalink)
Joey
Guest
Posts: n/a
Thanks Ray for this link, it's very helpful, but it doesn't mention what
to do with the 20A mini fuse ???
J
Ray O wrote:[color=blue]
>[color=green]
>>Hi all,
>>J[/color]
> [url]www.toyotaparts4u.com[/url] site and search wiring harnesses for your vehicle.[/color]
Old 09-16-2005, 05:24 PM   #5 (permalink)
Joey
Guest
Posts: n/a
Ron,
Maybe the 04 is different. The bottom of my spare tire from under the
vehicle has a round plastic disc that if you turn about one inch comes
off and exposes most of the spare tire. I'm just assuming that this kit
my local Toyota dealership sold me is the correct part.
ron wrote:
[color=blue]
> roughly 4-5 inches deep, about 7" wide and maybe 14" long mounted under
> the chasis to the bottom of the pan holding the spare tire. This box is
> where the plug in to the system electrical is. The box (or cover as you
> prefer) has quite a few drainage holes in it. I believe mine had a cap
> on it (from vehicle) - I plugged in pigtail (harness) and mounted it to
> the bumper. It is the flat 4 connector type with rubber cover.
> I bought the receiver from u-haul, installed just over 125 if I remember
> for type III
> ron[/color]
Old 09-16-2005, 05:26 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:11imcs3pi1j381@corp.supernews.com...[color=blue]
> J
>[/color]
If there is not fuse holder in the wire harness or in the black box, then
save the fuse in case another use comes up.
Ray O
correct the return address punctuation to reply[color=blue]
> Ray O wrote:[color=green]
>>[color=darkred]
>>>Hi all,
>>>J[/color]
>> [url]www.toyotaparts4u.com[/url] site and search wiring harnesses for your vehicle.[/color][/color]
Old 09-16-2005, 06:58 PM   #7 (permalink)
ron
Guest
Posts: n/a
sounds different Joey,
The spare on mine is inside the vehicle under the cargo deck.
The "box" I am referring to is attached by screws to underside of this
about exactly below the gas filler. you have 3 seats?
Old 09-16-2005, 08:30 PM   #8 (permalink)
Joey
Guest
Posts: n/a
No Ron, I don't have the third row of seats, only two. The pic/link
above shows the underside of mine (spare tire) just the way it appears.
J
ron wrote:
[color=blue]
>[/color]
Old 09-17-2005, 07:19 PM   #9 (permalink)
Joey
Guest
Posts: n/a
Finally decided to tackle the job today of wiring the hitch. I pulled
the left side in the rear on the inside and found the white plug where
this wiring kit attached. I connected the white ground wire nearby
where some other ground wires were attached. I pulled the grommit in
the bottom and the wiring kit's grommit fit in it's place after passing
the bottom wiring through this hole. I fastened the wiring harness
under the vehicle as shown in the instructions listed in an earlier
reply link. I had to put the 20 Amp fuse in the fuse box under the hood
which was marked 'towing'. Everything worked like it should. Thanks
all who answered my post for your assistance.
J
Joey wrote:[color=blue]
> J
> ron wrote:
>[color=green]
>>[/color][/color]
Old 09-17-2005, 11:08 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
news:11ip93f34pp6h0f@corp.supernews.com...[color=blue]
> Finally decided to tackle the job today of wiring the hitch. I pulled the
> left side in the rear on the inside and found the white plug where this
> wiring kit attached. I connected the white ground wire nearby where some
> other ground wires were attached. I pulled the grommit in the bottom and
> the wiring kit's grommit fit in it's place after passing the bottom wiring
> through this hole. I fastened the wiring harness under the vehicle as
> shown in the instructions listed in an earlier reply link. I had to put
> the 20 Amp fuse in the fuse box under the hood which was marked 'towing'.
> Everything worked like it should. Thanks all who answered my post for
> your assistance.
> J
>[/color]
Thanks for posting the results!
Ray O
> Joey wrote:[color=green]
>> J
>> ron wrote:
>>[color=darkred]
>>>[/color][/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
