Supra Tranny, Again. Need an MDT or a Service Rep here! ;)
OK. So the tranny doesn't shift, because s1 and s2 are toast. sL works,
but doesn't turn on because the speed sensor in the speedo is not sending
a signal, since the cable is toast.
SOOOOO, being the 'electronics genius' I am, how about:
I know which pins in the ECT connector control sL. I am assuming the O/D
switch on the shifter is wired to the ECT.
Now, if I remove the plug from the ECT (it's not functioning anyway) and
jumper from the pins from the switch to the pins for sL, I SHOULD be able
to control the Lock-Up (um, this IS the O/D, right???) and turn the O/D on
and off at will.
So, that means I'll have a 6-speed tranny? (No, not really)
Now, can anyone tell me, which are the pins from the switch?
And I wish I'd thought of this longer than a week or two before parkingthe
car for the winter!!!
Re: Supra Tranny, Again. Need an MDT or a Service Rep here! ;)
"Hachiroku" <Trueno@ae86.gts> wrote in message
news:pan.2005.10.02.23.05.25.902442@ae86.gts...[color=blue]
> and off at will.
> car for the winter!!![/color]
Hmmm. Try copying the relevant pages out of a manual at work then rig a
board with some switches to engage SL, S1, S2, and the torque converter
lockup. You'd have a poor man's tiptronic!
The lockup is not OD. It locks the torque converter so there is no
slippage. It's been a while, but I believe the shift sequence is 1 - 2 -
3 - 3/lock - 4 - 4/lock. I don't remember if the TC locks in 2nd gear or
not.
Ray O
correct the return address punctuation to reply
On Sun, 02 Oct 2005 20:14:03 -0500, Ray O wrote:
[color=blue]
> news:pan.2005.10.02.23.05.25.902442@ae86.gts...[color=green]
>> and off at will.
> not.[/color]
OK, how is 4th engaged? I only have L,2,3 on the stick, and the O/D
button. i top out on 3rd gear. How can I get 4th to engage? I though the
lock-up WAS 4th!
And, uh, what is work? I kinda mutually agreed not to return there. After
the change of ownership it just got worse...and worse...and worse...
news:pan.2005.10.03.19.18.04.894119@ae86.gts...[color=blue]
>[color=green]
>> news:pan.2005.10.02.23.05.25.902442@ae86.gts...[color=darkred]
>>> sending
>>> able
>>> on
>>> and off at will.
>>> parkingthe
>> not.[/color]
> lock-up WAS 4th![/color]
To be honest, I don't remember any specifics but I thought that 4th was a
combination of 2 shift solenoids. Lockup mechanically connects the pump and
turbine in the torque converter so that the inefficiency caused by having to
drive through a fluid is eliminated.
[color=blue]
> the change of ownership it just got worse...and worse...and worse...[/color]
Oh well, you interested in going to the place a little west of you that
sells Toyotas and Pontiacs?
Ray O
Jesus H Christ, Hachi. Your stuff is always good for a challenge,
definitely worth checking back in for. If you give me the specifics of
your Supra, I'll check the EWDs tomorrow at work, download some files for
you (if our POS computer is working...)
On Mon, 03 Oct 2005 18:30:41 -0400, qslim wrote:
[color=blue]
> you (if our POS computer is working...)[/color]
Yeah...I have no simple problem in my life!
And I'm always trying to 'engineer' something or other.
Never a dull moment in MY house!
Here's the deal. Thanks to
[url]http://www.cygnusx1.net/supra/library/TSRM/at/AT_029.html[/url]
[url]http://www.cygnusx1.net/supra/library/TSRM/at/AT_030.html[/url]
I've found that the OD switch and sL are right next to each other. Before
I run to Radio Shack to pick up some connector sockets, what would wiring
the O/D switch into the sL Lock-Up solenoid DO?
According to the TSRM, (in the same area; use Previous and Next to
navigate the pages) the shift positions for this car are L=1, 2=3 and
D=O/D. But it doesn't FEEL like O/D, it feels like third. 65 MPH on the
highway turns 3,000 RPMs. It seems to me this car should be turning ~2200
at 65 MPH, so i don't THINK it's going into O/D. Ray says turning on sL
will 'lock' the Torque Converter. I have to profess my ignorance here:
What does locking the TC do? Does it reduce RPMs?
Short of actually removing the tranny and replacing the solenoids, as a
short-term work around, does this acheive what I am attempting?
I'm raring to go! I've got all the materials (25 years of working in
electronics and being a pack rat will do that!) but before I go hacking
the system, what are the consequences?
Thanks, guys!
BTW, I located a car the same year and color (fender and door problems
solved!) with a 5-speed. Looks like a project for next spring! So this
will be a very short term fix indeed, since once the temps fall below 60
or so, the car goes back in the garage!
On Mon, 03 Oct 2005 14:29:16 -0500, Ray O wrote:
[color=blue]
> news:pan.2005.10.03.19.18.04.894119@ae86.gts...[color=green]
>>[color=darkred]
>>>> sending
>>>> able
>>>> on
>>>> and off at will.
>>>> parkingthe
>>> not.[/color]
>[color=green]
> sells Toyotas and Pontiacs?[/color]
They'd have to pay me pretty well to get me to go that far...or THERE! I'm
still hurting from the $700 AC repair that didn't!
One question I did want to ask, how do you get to be a regional rep?
Obviously, my technical expertise isn't up for a Tech Rep; what other
positions are available in Boston?
Well, the short answer to part of your question there is that OD and lock
up are two different things. OD is a 4th gear range. Thats it. 'lock up'
is when the torque converter, well, locks up. Usually, say at a stop, the
torque converters two turbines are released. If they weren't the engine
would stall (just like not pressing the clutch pedal at a stoplight). The
reason the torque converter locks up is to save fuel while cruising.
Also, looking at the wiring diagram on that site of yours, you only have
2 shift solenoids. S1 and S1. sL is indeed the lock-up control, as Ray
pointed out. Turning that thing on manually is probably not a great idea.
Having it on and off at the wrong times can dramatically affect the
driveability of the car.
Incidentally, I'm a bit late to party, I suppose, and I'm not quite
clear as to why you are doing all this. Is the trans not able to hold a
gear at all, or what is the deal?
On Mon, 03 Oct 2005 20:13:58 -0400, qslim wrote:
[color=blue]
> gear at all, or what is the deal?[/color]
s1 and s2=OPEN. No resistance (or conductivity) at all. THey're shot.
Also, the speedo is out, so the speed sensor does not read anything.
Probably the 'elbow' at the tranny that mates the cable to the gear
inside. These are known to go bad.
So, with these problems ,the tranny doesn't shift. I have to shift it
manually to go through the gears, but cruising RPMs, say, at 40MPH
(estimated, of course) are about 2200 and 65 is about 3000. Seems there
should be another gear. Or something. I thought this car had an
electronically controlled O/D (hence the O/D switch.) So...from what
you're tellin me is that s1 and s2 have to be WORKING to get into O/D
(seems to me I remember seeing that on the TSRM...)
But I DEFINITELY need to save fuel while cruising! This thing right now is
probably getting 16 MPG, if even that! It may even be as low as 12. i
can't measure it because, aside from the Odo not working, there's a hole
in the tank I can't find, so I can't fill it more than about 1/4 tank!
(shall I keep going? There's more!) So, I'm looking for a way to lower the
Rippems on the highway without ripping the tranny open; I haven't got the
soleniods anyway. They're $135 each. i can get another AT for $50, but if
I buy the other car for $250, I'll just swap the trannies. And the pedals.
Just was having thoughts how I could use the button on the shifter to
actuate...SOMETHING!
news:pan.2005.10.03.23.10.38.909283@ae86.gts...[color=blue]
>[color=green]
>[/color]
First of all, it's probably been at least 20 years since I looked at the
service manual for a Supra so I'm going by memory from the ECT class I took
(probably close to 30 years ago!).
If you think of the classic explanation of how a torque converter works - 1
electric fan plugged in facing another fan that is not plugged in. The air
blowing from the first fan moves the blades on the second fan, which in the
case of an automatic transmission, would be attached to the input shaft of
the tranny. If you apply the brakes and stop the blades on the second fan,
the first fan is still moving but the brakes on the second fan keep it from
spinning. This is how a TC slips when the vehicle is stopped. When you
release the brakes on the second fan and allow it to spin, there is some
inefficiency - that is, the second fan is not turning quite as fast as the
first powered fan. By locking the TC, that is, coupling the second fan to
the first one, there is no slippage. You lose the slippage, reduce the RPM
needed for a given speed, and gain some MPG.
[color=blue]
> Thanks, guys!
> or so, the car goes back in the garage![/color]
The solenoids work like a relay. IIRC, instead of controlling contacts,
they control shift valves. A combination of the solenoids give you the
different gears. I think that if the solenoids are shot, the transmission
goes into mechanical mode, at the loss of some gears. If the solenoids are
functioning, you could rig up a set of switches to control gears. The
tricky part, like qslm says, is making sure the TC is unlocked when
accelerating (so that you get torque multiplication from the TC and when
stopped so you get slippage and won't stall the engine.
Ray O
news:pan.2005.10.03.23.13.28.605564@ae86.gts...[color=blue]
>[color=green]
>> news:pan.2005.10.03.19.18.04.894119@ae86.gts...[color=darkred]
>>>>> works,
>>>>> sending
>>>>> O/D
>>>>> and
>>>>> able
>>>>> O/D
>>>>> on
>>>>> and off at will.
>>>>> parkingthe
>>>> a
>>>> 2 -
>>>> or
>>>> not.
>> and
>> to
>>[color=darkred]
>>> After
> still hurting from the $700 AC repair that didn't![/color]
Send me an e-mail if you're interested. I'll give you the name of the
owner.
[color=blue]
> positions are available in Boston?[/color]
The usual career path is to get hired right out of college as a management
trainee, or MT. MT's usually work in one of the departments at HQ in
Torrance or in the distribution, customer relations, or sales department at
one of the 10 Toyota-owned regional offices. A bachelor's degree is
minimum, masters is better. An MT will work 1 or 2 different departments in
a year or 2 and then get assigned a field job as a district parts manager at
a regional office, then district service manager, then district manager,
department manger, and then back to HQ for more jobs. People with
specialized skills like IT, logistics, manufacturing, engineering, or
automotive technical skills would go straight to the respective departments
but on a different career path. The field jobs and higher get benefits like
company cars, employee purchase for family, and personal lease cars for
immediate family members, expense accounts, trips to dealer shows every
year, etc. The employee lease is a much better deal than a normal retail
lease because it covers maintenance, repairs, and insurance for something
like 1% of dealer cost. For me, the lease payments on a loaded Previa were
less than the cost of insuring a 16 year old teen driver on a personal car
in Mass, and the wife got a new car every year. I've heard that you now
have to keep employee leases for 2 or 3 years but the payments are still
pretty low.
There are hourly jobs at parts distribution centers picking and stocking
parts. If the benefits are the same, you are eligible for employee
purchases after 6 months and employee leases after 5 years.
There are also hourly jobs at the port of entry (the closest ones to you are
in Newark, NJ and S. Boston. There are people who accessorize the vehicles,
drive them to the truck staging areas, detailers, etc.
Ray O
On Mon, 03 Oct 2005 23:45:54 -0500, Ray O wrote:
[color=blue]
> news:pan.2005.10.03.23.13.28.605564@ae86.gts...[color=green]
>>[color=darkred]
>>>>>> works,
>>>>>> sending
>>>>>> O/D
>>>>>> and
>>>>>> able
>>>>>> O/D
>>>>>> on
>>>>>> and off at will.
>>>>>> parkingthe
>>>>> a
>>>>> 2 -
>>>>> or
>>>>> not.
>>>> lock-up WAS 4th!
>>> and
>>> to
>>>> After
> owner.
>[color=green]
> pretty low.
> drive them to the truck staging areas, detailers, etc.[/color]
Thanks. Um, I don't think it's woryh going to S. Boston for detailing... :)
BUT, since you've been gone, they have a railhead in Brookfield most
likeley for the US made cars.
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote:
snip[color=blue]
>stopped so you get slippage and won't stall the engine.[/color]
So, Ray, you seem to be saying that ALL automatic transmissions
have a separate torque converter?. I used to think that this was
a function of the AT itself...do any manual transmission cars
have a torque converter?
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:bbb5k1d5nvr10uelvgab643r1uqhd08e8v@4ax.com...[color=blue]
> snip[color=green]
>>are
> -Gord.
> (use gordon in email)[/color]
I doubt if all automatic transmissions have a separate torque converter. I
thought VW's early Auto-Stick had some kind of automatic clutch and I have
not studied a CVT to see how it works so I don't know if it has a TC or not.
It is probably safe to say that all modern "conventional" automatic
transmissions with planetary gears have torque converters. A TC provides
torque multiplication when accelerating from a standstill, slippage when
stopped, and with modern electronics, lockup when cruising. Automatic
transmissions have come a long ways. I'd bet that almost all have a locking
torque converter, 4 and 5-speeds are common, and 6 speeds are starting to
show up so that performance and fuel economy are the same or better than
manual transmissions.
Ray O
> snip[color=green]
>>are
> -Gord.
