Re: how to clean an idle air control valve?
[email]onehappymadman@yahoo.com[/email] wrote:[color=blue]
> My '96 camry stalled again when making a left turn. Last time it
> stalled was about a month ago, I then cleaned the throttle body valve
> with toyota throttle body valve cleaner, both sides of the valve, and
> with a toothbrush. I thought that would have solved the problem.
> My next suspect is the idle air control valve. What is the correct way
> to clean this out? My Haynes manual discusses removal and electrical
> testing of the IAC valve, but not cleaning. I read somewhere on this
> group that the IAC valve can be cleaned by spraying carburetor cleaner
> into the rectangular duct just outside of the throttle body valve
> (lower-right side), while the engine is running. Is this procedure
> recommended? Or is there another way?[/color]
Probably should have waited for a reply first, but the idea sounded
like a good one, so I went ahead and did it. (Got the fire
extinguisher ready, just in case spraying a flammable chemical on a hot
engine did something... flammable.)
What an experience. A great sucking sound could be heard (I'd removed
the air intake hose), and the engine sounded like it was going to stall
each time I sprayed carburetor cleaner into the rectangular hole just
inside the throttle body. I sprayed a total of three times. Then I
shut down the engine, re-attached the air intake hose, and drove the
car around the block. So far so good. I'll have to wait about a month
to see if this did the trick...
