Key stuck in ignition cylinder lock, won't turn or start... HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Wheel & Tire Center
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.camry
alt.autos.toyota.camry Toyota Camry discussion newsgroup.
Old 03-21-2006, 01:48 PM   #1 (permalink)
eeee
Guest
Posts: n/a
View eeee's Photo Gallery
My '95 Toyota Camery ignition lock cylinder will not turn, thus the car
won't start. I'm trying to replace this lock cylinder but you have to
have the key in the ignition and turned to the "acc" position in order to
pull the cylinder. My problem is the key will not turn to the acc
position at all. It is stuck in the off position. Anyone, please help me
change the cylinder!!! Thank you, thank you, thank you!
Old 03-21-2006, 01:59 PM   #2 (permalink)
Nobody Important
Guest
Posts: n/a
View Nobody Important's Photo Gallery
Re: Key stuck in ignition cylinder lock, won't turn or start... HELP!!!
eeee wrote:[color=blue]
> won't start.[/color]
When this happens to me I just turn the steering wheel as far as it will
go in both directions while twisting the key. That always frees it up.
Old 03-21-2006, 03:30 PM   #3 (permalink)
eeee
Guest
Posts: n/a
Thanks, but I've tried that alreeady, didn't work. Any other
suggestions???
Old 03-21-2006, 04:30 PM   #4 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
> suggestions???[/color]
Sounds like you've got a stuck pin in the lock cylinder. Don't try to force
the key or lock as you can bend or gouge the pin and it may not retract. Go
to a Ford dealer and get an aerosol can of lock lube and penetrant. It
should only cost appx $5 and is the best product I've found for locks. I use
it in the fall instead of graphite lock lube.
You may have to work with it for a while, spraying and sliding key in and
out. When you try to turn the switch, like Nobody Important said, make sure
there is no tension on lock from steering wheel lock by turning steering
wheel slightly.
HTH, Dave
Old 03-21-2006, 04:48 PM   #5 (permalink)
eeee
Guest
Posts: n/a
Thanks, but now, after monkeying around with it all afternoon I broke the
key off in the ignition (@#$%&!) Any suggestions on how to remove the
cylinder, with the key broke off inside the cylinder, and unable to turn
the broke off key into the ACC position?
Old 03-21-2006, 05:00 PM   #6 (permalink)
eeee
Guest
Posts: n/a
Re: '95 Camry Key stuck in ignition cylinder lock, won't turn or start... HELP
Still looking for help/advice on changing out a ignition cylinder with the
key broke off in it and it not being able to turn to the ACC position.
Old 03-21-2006, 06:47 PM   #7 (permalink)
mrdarrett@gmail.com
Guest
Posts: n/a
View mrdarrett@gmail.com's Photo Gallery
> key broke off in it and it not being able to turn to the ACC position.[/color]
phonebook, locksmith?
Old 03-22-2006, 04:28 PM   #8 (permalink)
davidj92
Guest
Posts: n/a
> the key off in the ignition (@#$%&!) Any suggestions on how to
> remove the cylinder, with the key broke off inside the cylinder, and
> unable to turn the broke off key into the ACC position?[/color]
You're going to have to find a pick, possibly an old dental pick, to snag
the piece of key in cylinder and pull it out.
You may just want to drive it to to a locksmith and like mrdarrett posted,
get the whole thing fixed there.
Dave
Old 03-23-2006, 01:27 PM   #9 (permalink)
mrdarrett@gmail.com
Guest
Posts: n/a
davidj92 wrote:[color=blue]
> eeee wrote:[color=green]
> Dave[/color]
Or if he can't start the car, he might want to look in the yellow pages
for a locksmith who can travel to his house...
Mike Darrett
Old 03-24-2006, 05:11 PM   #10 (permalink)
davidj92
Guest
Posts: n/a
[email]mrdarrett@gmail.com[/email] wrote:
snip[color=blue]
> pages for a locksmith who can travel to his house...
> Mike Darrett[/color]
Good catch there, I forgot the point he can't use ignition switch. :-(
Dave
BB code is Off
Smilies are Off
[IMG] code is Off
OBDII codes Phi Hardcore Tech and Competition 13 07-02-2012 08:09 PM
FYI- How Transponder Keys Work Phi Audio, Video, and Security - Tech 3 01-02-2009 08:44 PM
turn key twice to start car. jamesmetairie Archived Corolla threads 15 06-10-2004 04:01 AM
96 Camry 4 cylinder won't start jjanari 3rd & 4th Generation (19921996 & 19972001) 1 06-02-2004 05:01 PM
Help: Ignition Lock Problem HeNry2kOoL Hardcore Tech and Competition 3 03-16-2004 09:46 PM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
