Re: A/C problem - Toyota Nation Forum : Toyota Car and Truck Forums
alt.autos.toyota.camry Toyota Camry discussion newsgroup.
post #1 of 4 Old 12-12-2006, 09:49 PM
ferd berford
Guest
Posts: n/a
Quoted: Post(s)
Re: A/C problem
HELLO wrote:[color=blue]
> 2003 4 cyl Camry My a/c has been powering off (compressor lights start to
> blink) I took it to the neighborhood shop and they could not figure it out
> everything seemed in order (no charge) . I'm afraid of what the toyota shop
> might charge so any Ideas on what is the problem is appreciated os I don't
> go there & get blindsided.
> Thanks
>[/color]
The blinking light means the compressor failed to start when the system
called for A/C, most likely a bad compressor relay on such a new car,
which is what my 2003 Camry needed. This was not too expensive, about
$112 to fix it and $86 to diagnose it. In the worse case it is a bad
compressor, middle case is a loss of R134 so the low pressure switch cut
out the compressor. If it is a low gas condition make sure they find and
fix the leak (for your sake and the environment).
post #2 of 4 Old 12-13-2006, 12:13 AM
Ray O
Guest
Posts: n/a
Quoted: Post(s)
Re: A/C problem
"ferd berford" <berferd@hotmail.com> wrote in message
news:YsSdndbpi4u99-LYnZ2dnUVZ_vyunZ2d@comcast.com...[color=blue]
> HELLO wrote:[color=green]
>> out
>> shop
>> don't
>> Thanks
>>[/color]
>[/color]
Actually, the blinking light means that the compressor RPM sensor detected a
different compressor RPM from the engine RPM. To re-energize the
compressor, turn the AC button off and then back on. If you heard a belt
squeal just before the light started flashing, the belt slipped and the
system shut down. Even if you did not hear a belt squeal, check AC
compressor drive belt tension - with the engine OFF, you should not be able
to depress the belt more than about an inch. If you can depress the belt
more than an inch, it got stretched out over time or the adjustment slipped.
Check the condition of the compressor drive belt. It should not be glazed
or cracked on the underside.
If the system needs a refrigerant charge, you would not get a flashing AC
light, the compressor would just not engage. An easy way to check
refrigerant charge is to look at the sight glass on the receiver drier in
front of the radiator. The receiver drier is s cylinder with steel lines
going into and out of the top. With the AC on, it should look like water is
flowing past the glass. If you see foam or nothing, the system needs
recharging.
Ray O
post #3 of 4 Old 12-13-2006, 10:05 PM
ferd berford
Guest
Posts: n/a
Quoted: Post(s)
Re: A/C problem
Ray O wrote:[color=blue]
> news:YsSdndbpi4u99-LYnZ2dnUVZ_vyunZ2d@comcast.com...[color=green]
>> HELLO wrote:[color=darkred]
>>> out
>>> shop
>>> don't
>>> Thanks
>>>[/color]
>>[/color]
> recharging.[/color]
I wonder if I paid for a relay (and diagnostics) that was not
needed..... A Toyota dealer wouldn't do that would they? Thanks for
the information, I was going on what the service manager told me and a
little bit of knowledge about the low pressure switch.
post #4 of 4 Old 12-14-2006, 12:32 AM
Ray O
Guest
Posts: n/a
Quoted: Post(s)
Re: A/C problem
news:FfSdnY6X954QIh3YnZ2dnUVZ_uzinZ2d@comcast.com...[color=blue]
> Ray O wrote:[color=green]
>> news:YsSdndbpi4u99-LYnZ2dnUVZ_vyunZ2d@comcast.com...[color=darkred]
>>>> to
>>>> out
>>>> shop
>>>> don't
>>>> Thanks
>>>[/color]
>> detected a different compressor RPM from the engine RPM. To re-energize
>> the compressor, turn the AC button off and then back on. If you heard a
>> belt squeal just before the light started flashing, the belt slipped and
>> the system shut down. Even if you did not hear a belt squeal, check AC
>> able to depress the belt more than about an inch. If you can depress the
>> belt more than an inch, it got stretched out over time or the adjustment
>> slipped. Check the condition of the compressor drive belt. It should not
>> be glazed or cracked on the underside.
>> is flowing past the glass. If you see foam or nothing, the system needs
>> recharging.[/color]
> I wonder if I paid for a relay (and diagnostics) that was not needed.....
> A Toyota dealer wouldn't do that would they? Thanks for the information,
> I was going on what the service manager told me and a little bit of
>[/color]
There is a technical service bulletin (TSB) # EL011-05 regarding the A/C
light flashing due to issues with the magnetic clutch relay. It is possible
that is the cause if the belt is OK.
Ray O
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.camry
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
« Back
