Mysterious Orange Dash Light Message - Toyota Nation Forum : Toyota Car and Truck Forums
alt.autos.toyota.camry Toyota Camry discussion newsgroup.
post #1 of 3 Old 12-28-2006, 10:44 AM
kadukchum
Guest
Posts: n/a
Quoted: Post(s)
Hello all,
Could someone please tell me what it means when an orange light goes on
every time I shift from "Park" to "Drive"? It looks like a picture of a
car with two "lights" on towards the back/rear of the car. It doesn't
come on when the car's turned on - only when I put it in gear.
Here's what I've been doing that's different from my usual driving
pattern: Moved from warm, flat Texas to snowy, hilly PA and have been
driving the car with the overdrive set to "Off" so I don't keep riding
the brakes going downhill in snowy, icy conditions. PLEASE tell me I
haven't messed up my transmission in any way. The car has only 74,000
miles and it's a 2000 Camry.
Thanks for the help!
post #2 of 3 Old 12-28-2006, 04:44 PM
username@mailserver.mail
Guest
Posts: n/a
Quoted: Post(s)
Re: Mysterious Orange Dash Light Message
On Thu, 28 Dec 2006 11:30:15 -0500, Nobody Important
<Dr.Xenon1@gmail.NOSPAM.com> wrote:
[color=blue]
>You hkadukchum wrote:[color=green]
>> Hello all,
>> car with two "lights" on towards the back/rear of the car.[/color]
>You have a burned-out brake light.[/color]
The orange light is an indicator that a rear light is out.
It will be off when you start the car.
If it goes on when you step on the brake peddle, you have a burned out
brake light. Don't forget to check the high center brake light too. If
you can't find a burned out brake light, it could be a dirty or
corroded connection to one of the bulbs, or it could be a "weak"
filament in a bulb.
Note: You have to step on the brakes to shift out of Park, so you
think it is coming on when you shift, but I'll bet is is coming on
when you step on the brakes.
If the orange warning light comes on when you turn the lights on, it
indicates a running light in the back of the car is out. Running
lights are the lights that come on when you turn the light switch to
the first position. These running lights stay on when you switch the
headlights on too.
post #3 of 3 Old 01-07-2007, 06:17 PM
kadukchum
Guest
Posts: n/a
Quoted: Post(s)
Thank you everyone for your help. It WAS my brake light that was not
working (the one in the center, inside the car).
[email]username@mailserver.mail[/email] wrote:[color=blue]
>[color=green]
> >You hkadukchum wrote:[color=darkred]
> >> Hello all,
> filament in a bulb.
> headlights on too.[/color]
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.camry
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
Back
