1990 Toyota Camry Water Temperature Sensor Location? - Toyota Nation Forum : Toyota Car and Truck Forums
alt.autos.toyota.camry Toyota Camry discussion newsgroup.
post #1 of 2 Old 05-21-2005, 12:43 PM
Joan McCrackin via CarKB.com
Guest
Posts: n/a
Quoted: Post(s)
Can anyone tell me where the water temperature senson is located on my 1990
Camry? The gauge isn't working, and I checked the check engine code, and it
gives me a "22" I think.
Message posted via CarKB.com
[url]http://www.carkb.com/Uwe/Forums.aspx/toyota-camry/200505/1[/url]
post #2 of 2 Old 05-21-2005, 11:45 PM
90camry
Guest
Posts: n/a
Quoted: Post(s)
Re: 1990 Toyota Camry Water Temperature Sensor Location?
For clarity, I am assuming that you have a four cylinder '90 Camry --if that
is the case, the water temperature sending unit is in the housing where the
upper radiator hose attaches to the motor. Look at the housing to the left of
where the upper radiator hose attaches--under that housing, sticking straight
down is the sending unit. There should be a wire or wires attached to the end
of the unit. I don't know if that would cause a "22" error code, but chances
are if the temp gauge isn't working, either the sending unit or the wire (or
wires) are bad.
"Joan McCrackin via CarKB.com" wrote:
[color=blue]
> [url]http://www.carkb.com/Uwe/Forums.aspx/toyota-camry/200505/1[/url][/color]
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.camry
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
