Re: oil leaking on engine head
"jodenesparks" <Power-Poster@power-post.org> sez:
[color=blue]
> I have a 95 toyota pickup 22R-E
> oil seems to be leaking from 3 of the 4 bolts on the top of the engine.[/color]
(I'm not sure what the proper name is). two sit next to the oil filter cap
and the other two are on the opposite end of the engine.[color=blue]
> on my most recent oil change, i was told that oil was leaking and my valve[/color]
needs to be replaced. I don't know the specific parts but I was quoted that
parts & labor for a the item circled is "valve gasket". It would come to
$195. Now I'm beginning to understand that this is a difficult job for a
beginner requiring engine removal. Is this correct?
No, what needs replacing is the valve cover gasket. You seem to have that
mixed up with replacing the valves ...
[color=blue]
> I would appreciate any pointers for better diagnosing the problem, as I'm[/color]
not sure what exactly which valve it is or if its all the valve components.[color=blue]
> I would also appreciate any possible ideas on a remedy for the leak.[/color]
All that entails is removing the cover by removing those 4 bolts, taking the
old gasket material out, cleaning out the oil/crud from the gasket channel,
putting new gasket in with perhaps a bit of RTV sealer and bolting the cover
back on.
Good wrenchin' to ya,
VLJ
