Re: Correcting speedometer
There are speedo calibration calculators on the 'net that will help you.
The easiest thing should be to go to an offroad shop (or a speed shop, in a
pinch) and see if they can help. Basically, the speed sender lives in the
transmission (transfer case if a 4WD) and picks up from the Output Shaft.
There is a small plastic gear that changes in size for the various tire and
gear set combinations.
Don't forget, since you made the tires much bigger, then you will alter the
performance curve on your truck. It won't have the same pick-up that it had,
and it won't perform as well on hills as it used to. This is a function of
the gear set in the differential(s). If yo have 4WD, then you have to change
the gear sets in both diffs, if you only have 2WD, then you only need to
change one gear set.
"Mike" <dieselcowgirl@gulftel.com> wrote in message
news:dk924m01f4r@enews4.newsguy.com...[color=blue]
> Just took my 87 Toyota 5 speed manual transmission and put 29 inch tires
> on
> it. The previous tires where about 26" diameter. Question> How do I get
> the
> speedo to read right? thanks.
>[/color]
