'83 pickup been running great since my timing belt change. I had to
regrease the bearings to pass state inspection, but didn't see any
problems with the old ones. When I put it into 4WD and turn at slow
speeds I get a lot louder, almost grinding noise and the steering
wheel feels resistant--it doesn't go away until I'm back straight again
(and move forward a little, I think). At higher speeds (10Mph+) it
works fine. Any ideas?
......and it's better at higher speeds because he's hopefully making wider
turns than he would while backing and turning out of a parking space or
driveway.
"Brad Taylor" <BradTaylor@ev1.net> wrote in message
news:11r5en6khh32k07@corp.supernews.com...[color=blue]
> Are you on hard pavement when trying this? The solid axle systems do not
> respond well to four wheel drive on hard, dry pavement. You will feel
> resistance in the steering and complaining from the chassis and driveline.
> Don't do it.
> <fowdawgg@gmail.com> wrote in message
> news:1135783122.209833.262730@o13g2000cwo.googlegroups.com...[color=green]
>>[/color]
>[/color]
Don't do it.
news:1135783122.209833.262730@o13g2000cwo.googlegroups.com...[color=blue]
>[/color]
Even so, my truck still complains at 30 mph. The steering is snappish and
the groaning is unbearable.
"Doug Kanter" <ancientangler@hotmail.com> wrote in message
news:AJzsf.2178$OU3.195@news01.roc.ny...[color=blue]
> driveway.
> news:11r5en6khh32k07@corp.supernews.com...[color=green]
> > Are you on hard pavement when trying this? The solid axle systems do[/color][/color]
not[color=blue][color=green]
> > resistance in the steering and complaining from the chassis and[/color][/color]
driveline.[color=blue][color=green]
> > Don't do it.
> > news:1135783122.209833.262730@o13g2000cwo.googlegroups.com...[color=darkred]
> >>[/color]
> >[/color]
>[/color]
news:11r6hdm30klg380@corp.supernews.com...[color=blue]
> the groaning is unbearable.[/color]
That's why you're not supposed to use it on dry pavement. :-) It's also the
reason why there are too many 4WD vehicles sold, without the customer being
informed of their limitations.
Doug Kanter wrote:[color=blue]
>[color=green]
>[/color]
It is also why the trend is for full time 4-wheel drive. Idiot proof
with a big service bill when things go wrong. I will stick with my older
Toyota instead of trading up to the always turning front axles.
- Different gears rear / front (doesnt match the problem but still ;)
Aside from that on PAVEMENT or grippy surfaces that grinding in turns
and steering resistance is 100% normal and a result of the 4WD system
with no center diff (which grinds a little tiny bit too).
For that reason one MUST NOT put the truck in 4WD on pavement and drive
turns. Driving 100% straight is ok.
By the way ... a 4WD system should be operated in 4WD for about 30 km a
month or every so often to prevent parts from ceasing/drying up and to
help splash oil in the diff around.
If you have manual hubs this is real easy to do and if you dont, you
can do that when going 100% straight in lets say a big parking lot.
news:RXVsf.2268$OU3.714@news01.roc.ny...[color=blue]
> news:11r6hdm30klg380@corp.supernews.com...[color=green]
> > Even so, my truck still complains at 30 mph. The steering is snappish[/color][/color]
and[color=blue][color=green]
> That's why you're not supposed to use it on dry pavement. :-) It's also[/color]
the[color=blue]
> reason why there are too many 4WD vehicles sold, without the customer[/color]
being[color=blue]
>[/color]
I don't. However, I was able to use it on my Jeep CJ-5 on wet pavement. It
was great for traction. My Toyota won't even let me use 4x4 on wet pavement
without griping.
"Jarhead" <baldintexas@excite.com> wrote in message
news:9redndLbmbb5pyneRVn-tw@amaonline.com...[color=blue]
> Doug Kanter wrote:[color=green]
> >[color=darkred]
> >>Even so, my truck still complains at 30 mph. The steering is snappish[/color][/color][/color]
and[color=blue][color=green][color=darkred]
> > That's why you're not supposed to use it on dry pavement. :-) It's also[/color][/color]
the[color=blue][color=green]
> > reason why there are too many 4WD vehicles sold, without the customer[/color][/color]
being[color=blue][color=green]
> >[/color]
> Jarhead[/color]
news:11r9i05faaauqb3@corp.supernews.com...[color=blue]
> news:RXVsf.2268$OU3.714@news01.roc.ny...[color=green]
>> news:11r6hdm30klg380@corp.supernews.com...[color=darkred]
> and[color=green][color=darkred]
> the[color=green]
> being[color=green]
>>[/color]
> It
> pavement
> without griping.
>[/color]
Are your tires much different than the ones on the Jeep? And, when you say
"wet pavement", are you talking about driving on days when the road's
intermittently "just wet", but still icy in some areas?
news:11rarjl1ej2p9b7@corp.supernews.com...[color=blue]
> news:xiatf.716$qg.188@news02.roc.ny...[color=green]
>> news:11r9i05faaauqb3@corp.supernews.com...[color=darkred]
>> >> > Even so, my truck still complains at 30 mph. The steering is[/color][/color]
> snappish[color=green][color=darkred]
>> > and
>> >> That's why you're not supposed to use it on dry pavement. :-) It's[/color][/color]
> also[color=green][color=darkred]
>> > the
>> > being
>> > pavement.
>> > It
>> > pavement
>> > without griping.
>> >[/color]
>> say
>>[/color]
> Well, we rarely have ice here in Houston. When we do, I stay off the
> roads
> because nobody here knows how to drive on ice. When I say wet, I mean
> from
> damp to flooding, but not alternatively dry and wet. Even the Jeep would
> hop on dry paving. The tires I had on the Jeep were National 11x33/R15
> bias
> type tires and I have BFG 235/75R15 All Terrain's on the Toy. I've
> learned
> to live with the difference. When it was a rainy day, I would lock the
> hubs
> and drive all over the place in 4wl-hi at speeds up to 50. I never had a
> problem with gripe, but it was noisy. I could power around corners with
> no
> fear of do-nuting or sliding. On wet, rainy surfaces in the Toy, it's
> like
> wrestling a bear, even with power steering. The Jeep was a neat off road
> vehicle, but it was cramped and I couldn't haul anything with it. I had
> planned to buy a Scrambler, but I was disappointed with the build quality
> in
> 1984 and had to look elsewhere. I ended up on the Toy because of the
> quality of craftsmanship that I saw. The Nationals were very stable and
> greatly increased the handling and stopping safety of that extremely short
> wheel base CJ-5. In short, they were sticky tires on dry pavement, and
> therefore must have been sticky on wet. The only thing left is the
> difference in drive-line construction between the Jeep and the Toyota.
> Both
> vehicles were plain jane and no auto slippage devices. I don't know what
> the difference is, but I wish that could drive the Toy the same as the
> Jeep
> on wet surfaces. I'm preparing to do some major suspension changes and
> all
> the other linkage upgrades that go along with that and am wondering,
> myself,
> if there is a way to correct this problem.
> I also learned some time back, that the Mud-Terrain's were no good for
> that
> truck because there wasn't enough rubber meeting the road. The truck
> would
> fishtail violently when braking at freeway speeds. When I applied the
> All-Terrain's the handling improved tremendously. In fact, I don't
> experience any fishtail, unless the paving is worn and slick.
> Well there's my ten cents.
>[/color]
Here's my ten cents: On wet roads (and I don't mean flooded, just wet),
there's no reason to be using 4WD. If your tires don't handle wet roads
nicely, you need better tires.
news:xiatf.716$qg.188@news02.roc.ny...[color=blue]
> news:11r9i05faaauqb3@corp.supernews.com...[color=green]
> > news:RXVsf.2268$OU3.714@news01.roc.ny...[color=darkred]
> >> > Even so, my truck still complains at 30 mph. The steering is[/color][/color][/color]
snappish[color=blue][color=green]
> > and[color=darkred]
> >> That's why you're not supposed to use it on dry pavement. :-) It's[/color][/color][/color]
also[color=blue][color=green]
> > the[color=darkred]
> > being[color=darkred]
> >>[/color]
> > It
> > pavement
> > without griping.
> >[/color]
>[/color]
Well, we rarely have ice here in Houston. When we do, I stay off the roads
because nobody here knows how to drive on ice. When I say wet, I mean from
hop on dry paving. The tires I had on the Jeep were National 11x33/R15 bias
type tires and I have BFG 235/75R15 All Terrain's on the Toy. I've learned
to live with the difference. When it was a rainy day, I would lock the hubs
problem with gripe, but it was noisy. I could power around corners with no
fear of do-nuting or sliding. On wet, rainy surfaces in the Toy, it's like
planned to buy a Scrambler, but I was disappointed with the build quality in
difference in drive-line construction between the Jeep and the Toyota. Both
the difference is, but I wish that could drive the Toy the same as the Jeep
on wet surfaces. I'm preparing to do some major suspension changes and all
the other linkage upgrades that go along with that and am wondering, myself,
I also learned some time back, that the Mud-Terrain's were no good for that
truck because there wasn't enough rubber meeting the road. The truck would
NEVER EVER DO THAT AGAIN FOR THE REST OF YOUR LIFE, especially on pavement,
wet or dry.
4WD on your truck is designed ONLY for offroad travel, or driving on a heavy
layer of snow. If you can see the pavement, then you shouldn't be using 4WD.
If you look at the axles, you will see large bulb-shaped structures in the
middle. These are differential gears, where the driveshaft spins the pinion
gear, which in turn turns the ring gear. As you go around corners, the left
and right side tires turn at different speeds -- the differential makes this
possible.
Now, consider that in 4WD, not only do the left and right side tires turn at
different speeds, the front and rear tires ALSO turn at different speeds.
The transfer case connects the front and rear drive lines, but the tcase has
no differential capabilities, so any stress that develops by the different
speeds of the tires is released through the tires slipping on the ground. If
the tires can get a grip on the ground, they won't slip, and the stress will
be transmitted back through the steering wheel as a wobble.
If you can hear the complaints, prepare your checkbook for transfer case
service. This would be a good time to start thinking about a 4:1 Kit for the
tcase if you are into any sort of serious offroading.
>[/color]
By your answer you must think I am a complete damn idiot. Well you can take
your advice, snotty attitude and yelling and shove it. I've been
successfully driving on and off road for 35 years and I know how the axles
and drivetrain work. Why do you think they make all wheel drive cars for
better handling? I had great traction with the Jeep in 4WD Hi on wet
pavement and NEVER damaged the driveline. However, the Toyota won't do it,
so I DON"T DO IT! Go be snotty to someone else jack ass.
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:NqSdne3RG6N3iyvenZ2dnUVZ_tudnZ2d@ez2.net...[color=blue]
> NEVER EVER DO THAT AGAIN FOR THE REST OF YOUR LIFE, especially on[/color]
pavement,[color=blue]
> wet or dry.
> 4WD on your truck is designed ONLY for offroad travel, or driving on a[/color]
heavy[color=blue]
> layer of snow. If you can see the pavement, then you shouldn't be using[/color]
4WD.[color=blue]
> middle. These are differential gears, where the driveshaft spins the[/color]
pinion[color=blue]
> gear, which in turn turns the ring gear. As you go around corners, the[/color]
left[color=blue]
> and right side tires turn at different speeds -- the differential makes[/color]
this[color=blue]
> possible.
> Now, consider that in 4WD, not only do the left and right side tires turn[/color]
at[color=blue]
> The transfer case connects the front and rear drive lines, but the tcase[/color]
has[color=blue]
> speeds of the tires is released through the tires slipping on the ground.[/color]
If[color=blue]
> the tires can get a grip on the ground, they won't slip, and the stress[/color]
will[color=blue]
> service. This would be a good time to start thinking about a 4:1 Kit for[/color]
the[color=blue]
> >[/color]
>[/color]
