94 4'runner timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-31-2005, 05:57 PM   #1 (permalink)
fartking
Guest
Posts: n/a
View fartking's Photo Gallery
I am changing the timing belt on a 94 4'runner with the 3.o liter v6
engine. Is the crank shaft pulley bolt right hand or left hand thread? I
have tried just about everything to get it loose...... any suggestions?
Old 01-01-2006, 03:45 PM   #2 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: 94 4'runner timing belt
It's a normal thread, it's just really on there. I wrap a chain wrench
around the crank pulley and then put a three foot breaker bar with a
socket on the bolt, and pull like hell. It takes two people sometimes.
Old 01-02-2006, 05:43 PM   #3 (permalink)
Coolguy
Guest
Posts: n/a
View Coolguy's Photo Gallery
The easiest way is to get a 24" x 3/4" steel pipe from home depot and stick
your socket wrench into it. Put the pipe under and against the body frame on
the passenger side. Have someone hold the socket wrench in place. Crank the
engine slightly, the camshaft bolt should crank loose. I just did it
recently to replace the timing belt on my 1990 4runner.
fartking wrote:[color=blue]
>have tried just about everything to get it loose...... any suggestions?[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 10:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 03:59 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 05:22 AM
94 Celica ST timing belt question BEI Celica Forum 1 06-21-2005 10:04 AM
