'91 4wd Wheels Question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-04-2006, 11:09 PM   #1 (permalink)
NJ
Guest
Posts: n/a
View NJ's Photo Gallery
I have a '91 ext cab 4wd Toyota PU. I have been looking for some take offs
that will fit the truck. I have a complete set of tires and wheels for a
2001 Chevy Z71. I tried these wheels and they would not fit. Yet I see
several posts on ebay where they say the wheels are interchangable...????
I'm also looking for a way to remedy the drivers side seat cushion. Feels
like I'm sittingin in a bucket when driving...
I'll look forward to feedback..
Thanks
NJ
Old 01-08-2006, 01:37 PM   #2 (permalink)
EasyE
Guest
Posts: n/a
View EasyE's Photo Gallery
Re: '91 4wd Wheels Question
Your LUG pattern is 6X5.5 Alot of Chevy's are as well... but not all.. What
do you mean won't fit? Won't fit on the Studs? Or the wheel and tire won't
fit in the wheel-well due to clearance issues.... If it's clearance issues,
then common sense would tell you that either the back spacing on the Chevy
Rims is wrong, or your trying to stuff entirely too big of tires on it..
"NJ" <nwilliams@door.net> wrote in message
news:PeqdnbLdEoTCPCHeRVn-ig@valortelecom.com...[color=blue]
> Thanks
> NJ
>[/color]
Old 01-09-2006, 11:11 AM   #3 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sun, 08 Jan 2006 18:37:37 GMT, "EasyE" <ezeuconn@hotmail.com>
wrote:[color=blue]
>news:PeqdnbLdEoTCPCHeRVn-ig@valortelecom.com...[/color]
[color=blue][color=green]
>> several posts on ebay where they say the wheels are interchangable...????[/color][/color]
Of course they claim this - they want the money. Duh! ;-P
[color=blue]
>Rims is wrong, or your trying to stuff entirely too big of tires on it..[/color]
Sometimes the center hub hole is the problem - IIRC the Chevy is a
smaller wheel bearing area than the Toyota. The lugs would line up
perfectly IF you could get the wheel over the bearings...
>> like I'm sitting in in a bucket when driving...[/color][/color]
Check with the Dealer parts counter. You can buy a new seat cushion
foam as a complete pre-molded item. Remove the seat, pop off the
outer cover, pull out what's left of the old foam cushion, install the
new cushion and reverse the procedure.
If it's just shaped wrong for you, they can be opened up and
bolstered by any good upholstery shop. A fresh layer of batting or
another inch of foam to fill in that 'hole in the bucket'.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
BB code is Off
Smilies are Off
[IMG] code is Off
91 Speedo Cable Question johnr MR2 Forum 9 10-28-2005 09:15 PM
question for the stock wheels!! 2000LEV6 Camry & Solara Lounge 9 09-20-2005 11:33 AM
'91 turbo throttle cable question ryde MR2 Forum 4 05-23-2005 03:22 PM
Question about wheels '95 Avalon XLS Camry & Solara Lounge 3 03-03-2005 04:29 AM
