I let a guy work on my engine and he offered to disable smog control...
I was like sure, he went and went to work, he clipped tons of wires
that are on that little plate that bolts to the valve cover, plugged
ALL the tubes, and turned on the engine, it seemed to run fine, but now
I am having tons of trouble with my engine, it may be the timing chain,
or maybe that? help?
On 5 Jan 2006 13:08:32 -0800, "ThoseWhoHatedMeCreatedMe"
<thosewhohatedmecreatedme@gmail.com> wrote:
[color=blue]
>or maybe that? help?[/color]
You didn't mention that little factoid in the other post with the
timing chain concerns - it's a 1992 22RE engine, right?...
You have some damned serious problems here - I've heard it's a stone
cold pain in the keester to get all the smog equipment off an EFI
engine properly and make it run right, the computer gets all screwed
up from data not arriving from disconnected sensors.
Or the EFI Computer tries to change the timing or bump up the idle
by closing a vacuum valve that doesn't exist anymore, and nothing
happens - so it panics, throws the Check Engine light on and goes into
Open Loop "Limp-Home" Mode where it runs like crap, but it runs...
"I'm helping!!" BULLPUCKY. Go back to "that guy" and he either
gets it running right, or he puts it all back the way he found it.
Like it or not, it's an integrated system that all has to be there to
work right.
And if you live anywhere that a State Smog Inspection is required -
either biennially like California does to renew the registration or
when you sell the vehicle - Congratulations, you just let him turn
your car into Scrap Metal. Seriously. It may be easier and cheaper
to junk the truck than to locate and rebuild all the wiring
connections, sensors, hoses, vacuum switching valves, and other
necessary stuff he just snipped and trashed.
Without that smog certificate, you can kiss the license plates
goodbye. They'll spot the carnage in a heartbeat, the smog station
guys all know what's supposed to be there. And they are almost
impossible to bribe - because if the State gets wind of a station
faking tests, they send an inspector in undercover with a doctored car
and a wad of crisp Twenties in their pocket. If the smog operator
takes the bait and fakes a Pass test his license is gone.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
The guy used to work for NASA, he has a 22re just like mine and his
runs perfectly, with the smog control disabled exactly the same, i live
in hawaii so that stuff doesnt even matter, you dont even have to bribe
the people here haha, we dont got no test like that.
he was the inventor of the high speed alternator and a few other
things, hes my friends personal mechanic for his 8 second race car, he
built the EFI unit for that car, literaly, built it himself, he bought
the little ics and all that stuff and spent days on end soldering and
tuning.
umm..... the guy has the same exact engine as me and his runs perfect,
he did the same exact thing as my engine... used to work for nasa, he
really knows his stuff electronicly wise, i was hoping it was just
something obvious.
I think the problem is a loose nut behind the wheel.
Q
ThoseWhoHatedMeCreatedMe wrote:[color=blue]
> something obvious.
>[/color]
On 5 Jan 2006 23:16:04 -0800, "ThoseWhoHatedMeCreatedMe"
[color=blue]
>the people here haha, we dont got no test like that.[/color]
Yet.
Don't think the Feds aren't trying for it in all 50 states. They'll
come up with a way to tie it to a highway funding or defense bill
eventually - do a biennial smog check, or "No Dollars For You!"
[color=blue]
>tuning.[/color]
If he's willing to help get your car running right, and he can, go
for it. (If he can't, why did he do it in the first place?)
But if you were only at the 'thinking about it' stage before ripping
out the Smog stuff, my suggestion would be an emphatic "If it ain't
broke, don't 'fix' it! Leave It Alone!" Those sensors are there so
the EFI computer can adjust the timing and fuel delivery to changing
conditions, and now (depending on exactly what he removed) the
computer has no idea about what some of the conditions are or it can't
change the engine parameters to make it run it's best.
But it's very bad timing because now you have multiple problems and
it will be hard to pin down what's at fault. Is it the cam timing, or
is it the EFI causing it to run like crud? Or something else?
--<< Bruce >>--
Well, i hear what your saying and it does make sence, the guy told me
he would install this timing chain for me free on sunday, but the
engine never ran right since i let other people work it, this guy
acauly made it run better. the things he cut he said would only make
the engine not turn up the idle when the AC was turned on.
someone who worked for the people that tested smog control told me that
the guy did a good job too, he said just make sure EVERYTHING is
plugged up and nothing is shorted. we disabled the computers timing
control for a little so it was just the distributor and it ran exactly
the same. you dont know of any sensor that is like, super obvious
that could cause this?
I don't know what your problem is... i removed "MOST" of my 22re smog
equipment on my 94' pickup and it runs like brand new... sooo I'm guessing
he only pulled stuff like the EGR ... which really doesn't do jack shit
anyway. I removed mine, I've never encountered a problem... sounds like you
have a timing problem... those things are a bitch to get just right..
Ian
"Q" <hugemoth@access4less.net> wrote in message
news:Wguvf.3701$Hl6.2778@newsread3.news.pas.earthlink.net...[color=blue]
> Q
> ThoseWhoHatedMeCreatedMe wrote:[color=green]
> > something obvious.
> >[/color][/color]
[color=blue]
>[/color]
The whole word is choking in smog and you go and disable your emision
control. Great. Hope a big tree that died from acid rain falls on your
truck with you in it.
we dont have emission laws here in a hawaii for a reason you moron.
do you have any idea how much polution harleys put out? strait piped?
or what about deisels? or how about air planes? tour boats anyones?
oooohhh... 2 strokes! they are nice, on idle u can watch trees die.
cmon man, my truck is tuned to run great and i use it for offroading
only...
ohh another thing, before the days of EFI, carbs were used, imagine
those muscle cars with their nice 454 ci engines, ohh yeah, but its MY
truck thats gonna kill the trees.
have a nice day
brian
ps. you are a moron. come to hawaii, look at the adverage veicle,
they cant even pass a simple safty check, i think that emissions are
the LAST concern here.
In article <vOednXvorZwh3SLeRVn-gQ@bresnan.com>, [email]mchevalier@bresnan.net[/email]
says...[color=blue]
>[color=green]
>>[/color]
>truck with you in it.[/color]
"JJones" <jjones_0001@yahoo.com> wrote in message
news:821wf.484$Hd4.49@newsread1.news.pas.earthlink.net...[color=blue]
> says...[color=green]
>>[color=darkred]
>>>[/color]
> What a mean thing to say.
> jj
>[/color]
Yeah, especially when you consider the "whole world" is not choking in smog.
This is a condition far more prevalent in 3rd world metro centers such as
Mexico City.
"Philip" <1chip-state1@earthlink.net> wrote in message
news:hX1wf.3717$ZA2.2307@newsread1.news.atl.earthlink.net...[color=blue]
> news:821wf.484$Hd4.49@newsread1.news.pas.earthlink.net...[color=green]
> > says...[color=darkred]
> >>> I let a guy work on my engine and he offered to disable smog[/color][/color][/color]
control...[color=blue][color=green][color=darkred]
> >>> ALL the tubes, and turned on the engine, it seemed to run fine, but[/color][/color][/color]
now[color=blue][color=green][color=darkred]
> >>> I am having tons of trouble with my engine, it may be the timing[/color][/color][/color]
chain,[color=blue][color=green][color=darkred]
> > jj
> >[/color]
> Yeah, especially when you consider the "whole world" is not choking in[/color]
smog.[color=blue]
> Mexico City.
> - Philip
>[/color]
