Re: Noise in the cab at one rpm only.
Greetings,
How about a loose baffle plate in the muffler or a loose heat shield
between the muffler and cab floor? Or maybe a heat shield in the engine
compartment...
Bill
"zlen357" <h_l_greene@yahoo.com> wrote in message
news:1137022672.337964.84840@o13g2000cwo.googlegroups.com...[color=blue]
>I have a 1988 Toyota, carbureted 2WD pickup. The truck has a very quiet
> exhaust system but at a low rpm just above idle it makes an annoying
> "vroom" sound in the cab each time it passes through that rpm. If that
> rpm is held steady it will continue. There is no such sound at any
> other engine speed. The truck need not be moving. It is so annoying
> because that rpm occurs so much in city driving that the "vroom" is
> coming and going constantly. It's hard to guess, but the rpm seems to
> be around 1000. Maybe a little higher.
> I've searched the groups for advice and thus have jacked up the engine
> while watching all the motor mounts, and all the following. The exhaust
> system is in good shape and properly supported. My efforts to locate
> the source of this noise have been mostly by doing things that would
> stop the noise so I could figure out what to do. I have weighted the
> exhaust pipe at different places to stop any resonating(?) I also put
> the jack under it for the same test. It had no affect.
> I hooked a hoist to the front of the engine and pulled it up hard, but
> it didn't help. I weighted the engine down about a hundred pounds to no
> avail. I took off the A.C. and smog pump belt. That made no difference.
> I held the fan still while running the engine. No help. The 22r just
> seems to love to vibrate at that rpm and it sounds like someone beating
> a drum in the cab. Something is resonating. Any suggestions? I am so
> stumped that the only other thing I could think of was to come in the
> house and join this newsgroup and ask you. It's my first post.
> Thanks for any advice you have.
>[/color]
