Do remote starters work on manual tranmissions? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-13-2006, 03:18 PM   #1 (permalink)
Brian
Guest
Posts: n/a
View Brian's Photo Gallery
I own a 03 tacoma manual 5 speed. Is there any after market remote
starters out there for the manuals?
Old 01-13-2006, 06:51 PM   #2 (permalink)
Searcher
Guest
Posts: n/a
View Searcher's Photo Gallery
Re: Do remote starters work on manual tranmissions?
OF course they would work, But the risk of injury and damage is great! You
would have to be positve that the truck was in neutral and the E brake was
set.. Remote starters are notmade for vehicles with manula trannys, and they
say so on the packaging. But thats not to say it won't work.
Searcher
Old 01-13-2006, 08:42 PM   #3 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
"Brian" <brianinmilo@webtv.net> wrote in message
news:591-43C80B22-474@storefull-3137.bay.webtv.net...[color=blue]
>[/color]
No. How would the stater know the vehicle is not in gear?
Old 01-13-2006, 09:04 PM   #4 (permalink)
Searcher
Guest
Posts: n/a
Hey, I never thought about a clutch cut off switch. Used to be that you
could engage the starter and get "unstuck" if the engine dies.
Searcher
Old 01-13-2006, 11:30 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Fri, 13 Jan 2006 14:18:42 -0600, [email]brianinmilo@webtv.net[/email] (Brian)
wrote:
[color=blue]
>starters out there for the manuals?[/color]
They are illegal to put on a manual transmission car in most states.
And no installer or mechanic in his right mind would hook one up for
you - he would share in the legal liability, and they could clean him
out down to his skivvies and toothbrush, too. You could do it all by
yourself, but the legal ramifications would stop any sane person.
If anything went wrong and the car started in gear, and became a
runaway and caused a bunch of property damage or injured or killed
people, you would be 100% on the hook for the responsibility. Your
car, homeowners, and even blanket liability insurance policies would
deny the claims - they don't cover Gross Negligence.
And the companies that make the auto start systems say in no
uncertain terms they are not to be used on a manual transmission car,
so you can't pawn any of the responsibility off on them.
It would work IF you could come up with a proper method to make sure
the transmission was in neutral and the parking brake securely set.
It would be even better if you had a sure-fire way to physically lock
the transmission in Neutral, like a restriction plate inside the cab
that goes over the shifter arm to physically lock it in Neutral and
only completes the safety circuit when it's in place.
(It could be done, but it would also look like hell inside the
truck. They put shifter restriction plates on tow-behind forklifts so
there's no way they can go into gear when being towed on the street.)
And manual transmissions don't have a park pawl - to make sure that
the brakes are set, you'd have to install a Mico-Lock system like used
in medium trucks with hydraulic brakes, where it puts a check valve to
hold the service foot brakes on as a backup to the parking brake
system. [url]http://www.mico.com/[/url]
With the simple lever-lock valves you close the dashboard check
valve then stomp on the brake pedal hard to set the service brakes.
They have a pressure switch that is activated only when the service
brakes are properly applied.
And if the hydraulic pressure leaks down overnight - or more likely
the cold overnight temperatures will drop the brake pressure below the
threshold, the safety switch will open and the car won't start. You
would need to buy a system from the Model 691 family that has a built
in motor and pump to keep the pressure up overnight, and if you
thought the plain valve system was expensive...
By the time you get through putting enough fail-safes on the car to
safely install an auto-start system, it would be far cheaper easier
and simpler to sell your truck and buy another one with an automatic
transmission.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 01-14-2006, 12:50 AM   #6 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:EfidneP3zfDCxVXenZ2dnUVZ_t-dnZ2d@ez2.net...[color=blue]
> news:591-43C80B22-474@storefull-3137.bay.webtv.net...[color=green]
>>[/color]
>[/color]
You can buy a ring with micro switchs built round it that mounts at the
bottom of your gear stick. It is disable for auto start.
They are a bastard to set up correctly though.
Old 01-14-2006, 12:51 AM   #7 (permalink)
Scotty
Guest
Posts: n/a
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:l0tgs1hht1es4c8ohmkjg0e2k2ij3l0nab@4ax.com...[color=blue]
> wrote:
>[color=green]
> transmission.
>[/color]
Or buy an auto!
Old 01-14-2006, 06:11 AM   #8 (permalink)
Bonehenge
Guest
Posts: n/a
View Bonehenge's Photo Gallery
On Sat, 14 Jan 2006 02:04:52 GMT, "Searcher" <ACBRN@CS.ver.aol.com>
wrote:
[color=blue]
>Hey, I never thought about a clutch cut off switch.[/color]
Newer stick shift TRD Tacomas have a factory clutch switch bypass.
It's really handy when starting it to clean off the snow, too!
Reach in, check the parking brake is on and it's not in gear, turn the
key, hit the switch, voila! No need to get all kinds of snow in the
cab.
Old 01-14-2006, 06:18 AM   #9 (permalink)
Bonehenge
Guest
Posts: n/a
On Sat, 14 Jan 2006 04:30:28 GMT, Bruce L. Bergman
<blPYTHONbergman@earthlink.invalid> wrote:
[color=blue]
>transmission.[/color]
Then, you too can come out of a store and have no idea why your
vehicle is running when you didn't push the button. My brother's
Taurus is constantly doing this
You too can destroy your fuel mileage by allowing the car to idle for
30 minutes at a time before a 15 minute ride, as my neighbors do on a
regular basis.
I'd never buy a vehicle with a remote start installed, as I have no
idea how much wear is really on the engine. Install a Hobbs meter
with the remote start, and I'd think about it. <G>
I use an older idea, it's called a garage...
Old 01-14-2006, 12:09 PM   #10 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Bonehenge wrote:[color=blue]
>[/color]
I guy I used to work for bought a used Lexus LS400 which would start on it's
own at random times. After a few times of it doing this he took it to his
mechanic, who found an aftermarket remote start unit the previous owner
hadn't told him about. It was obviously going south so he had it removed.
davidj92
Old 01-14-2006, 12:55 PM   #11 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On Sat, 14 Jan 2006 15:51:53 +1000, "Scotty" <scoter1@warmmail.com>
wrote:[color=blue]
>news:l0tgs1hht1es4c8ohmkjg0e2k2ij3l0nab@4ax.com...[color=green]
>> wrote:[/color][/color]
[color=blue][color=green][color=darkred]
>>[/color][/color]
<Big Snip to the last paragraph>[color=blue][color=green]
>Or buy an auto![/color]
Gee, I just said that... Did you actually read first? ;-P
--<< Bruce >>--
Old 01-14-2006, 01:54 PM   #12 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
news:t5dis1lmsek4fvj6q9vpgc9o2sbpc1iq7g@4ax.com...[color=blue]
> wrote:[color=green]
>>news:l0tgs1hht1es4c8ohmkjg0e2k2ij3l0nab@4ax.com...[color=darkred]
>>>[/color][/color]
> <Big Snip to the last paragraph>[color=green][color=darkred]
> --<< Bruce >>--[/color]
Cars and trucks have had clutch interlocks for a long time. 10yrs anyway.
So if your remote starter device were wired through the ignition switch,
you'd be okay ... which it should be with an automatic too. Automatic cars
have had an interlock with the brake pedal for at least 10 years.
- Philip
Old 01-14-2006, 02:29 PM   #13 (permalink)
Joe
Guest
Posts: n/a
View Joe's Photo Gallery
There is no reason for it not to work, the danger is that you could start it
in gear with catastrophic results if you could rig a neutral switch some how
no problem. One solution is you could master switch it through the park
brake and ensure you leave it in neutral, a bit risky to starter if left in
gear, we dont have cold here can you leave the park brake on when freezing?
Joe
>[/color]
Old 01-14-2006, 02:42 PM   #14 (permalink)
ThoseWhoHatedMeCreatedMe
Guest
Posts: n/a
View ThoseWhoHatedMeCreatedMe's Photo Gallery
I have one on my truck. Truck starters are ment to have torque so that
you can start them in gear for many differnt reasons... I do NOT
suggest you install one, I always leave my truck in neautral, but I
made a mistake once and left it in gear, it ran over my friends foot
and headed strait for his 500,000.00 race car, luckly I was able to get
in and stop it before anything happened to the car and my friend was
wearing steel toes. so no matter. None the less, it could have been
really messy
Old 01-14-2006, 03:32 PM   #15 (permalink)
Jeff Strickland
Guest
Posts: n/a
"Philip" <1chip-state1@earthlink.net> wrote in message
news:zNbyf.7420$ZA2.440@newsread1.news.atl.earthlink.net...[color=blue]
> news:t5dis1lmsek4fvj6q9vpgc9o2sbpc1iq7g@4ax.com...[color=green]
>> wrote:[color=darkred]
>>>> wrote:[/color]
>>[color=darkred]
>>>>[/color]
>> <Big Snip to the last paragraph>[color=darkred]
>>>> transmission.
> cars have had an interlock with the brake pedal for at least 10 years.
> --[/color]
But the interlock switches on a manual and an atuomatic serve entirely
different purposes. The manual trans has the interlock mounted on the clutch
pedal, and requires the clutch to be depressed in order to engage the
starter, the automatic's interlock is mounted on the brake pedal, and
requires the brake to be applied before one can shift from Park into a gear
that results in the car going somewhere.
In the manual, the car can not be started unless the clutch is depressed, in
the automatic car, has to be in park or neutral (but as a practical matter,
how many people leave a car in N?). The vast majority of drivers leave a
manual tranmission in gear, either 1st or R, and it would be senseless to
have Remote Start in this case -- the status of the Clutch Safety Switch
notwithstanding. The interlock on the automatic prevents the car from moving
inadvertanlty after it is already started, the interlock on the manual
transmission prevents the car from even starting. Two completely different
uses ...
BB code is Off
Smilies are Off
[IMG] code is Off
Anyone Have Experience With Prostart Remote Starters? Vato Loco Audio, Video, and Security - Tech 11 05-15-2005 01:32 PM
Car Alarm/Keyless Entry Remote elvasoshexai Audio, Video, and Security - Tech 1 10-20-2004 10:16 PM
Universal Remote techguy Audio, Video, and Security - Tech 0 09-19-2004 05:24 PM
1997 RAV4 RS3000 Remote sixpackbird Audio, Video, and Security - Tech 0 07-01-2004 11:19 PM
Avalon remote (how do I know if it will work with my car?) mpoyner Audio, Video, and Security - Tech 1 06-14-2004 02:22 PM
