rad problem, temp spikes then drops - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-18-2006, 03:20 PM   #1 (permalink)
neophyte
Guest
Posts: n/a
View neophyte's Photo Gallery
replaced thermostat on 92 22re, top up antifreeze in rad, the rad fills up
the overflow rez and spills out. the engine tempgauge gets alomost to the
red line as I first start driving then drops really quickly. Anyone have any
ideas, airlock?
Old 01-18-2006, 11:25 PM   #2 (permalink)
Chips
Guest
Posts: n/a
View Chips's Photo Gallery
Re: rad problem, temp spikes then drops
Replace the thermostat again. Is it in backwards?
"neophyte" <srfral@sympatico.ca> wrote in message
news:Idyzf.7621$924.159980@news20.bellglobal.com...[color=blue]
> any
> ideas, airlock?
>[/color]
Old 01-19-2006, 01:51 PM   #3 (permalink)
EasyE
Guest
Posts: n/a
View EasyE's Photo Gallery
does your top radiator hose get hot??? sounds like a potential head
gasket...
"Chips" <Chips1@reliableins.nospam> wrote in message
news:RoFzf.8450$_S7.4225@newssvr14.news.prodigy.com...[color=blue]
> news:Idyzf.7621$924.159980@news20.bellglobal.com...[color=green]
> > replaced thermostat on 92 22re, top up antifreeze in rad, the rad fills[/color][/color]
up[color=blue][color=green]
> > the overflow rez and spills out. the engine tempgauge gets alomost to[/color][/color]
the[color=blue][color=green]
> > any
> > ideas, airlock?
> >[/color]
>[/color]
Old 01-19-2006, 05:30 PM   #4 (permalink)
neophyte
Guest
Posts: n/a
yes top hose gets hot but no symtoms of head gasket, if it is head gasket
what should I be looking for. replaced rad cap as well.
"EasyE" <ezeuconn@hotmail.com> wrote in message
news:15Szf.903$ur7.428@newssvr33.news.prodigy.com...[color=blue]
> gasket...
> news:RoFzf.8450$_S7.4225@newssvr14.news.prodigy.com...[color=green]
> > news:Idyzf.7621$924.159980@news20.bellglobal.com...[color=darkred]
> > > replaced thermostat on 92 22re, top up antifreeze in rad, the rad[/color][/color][/color]
fills[color=blue]
> up[color=green][color=darkred]
> the[color=green][color=darkred]
> > > red line as I first start driving then drops really quickly. Anyone[/color][/color][/color]
have[color=blue][color=green][color=darkred]
> > > any
> > > ideas, airlock?
> > >[/color]
> >[/color]
>[/color]
Old 01-19-2006, 10:02 PM   #5 (permalink)
Mike
Guest
Posts: n/a
View Mike's Photo Gallery
news:0eVzf.20294$xk1.471397@news20.bellglobal.com...[color=blue]
> what should I be looking for.[/color]
Symptoms of a blown head gasket would be coolant forced out of the
radiator into the resevoir and engine running hot/overheating. Did you have
those same symptoms before you replaced the thermostat ?
Old 01-20-2006, 11:38 AM   #6 (permalink)
EasyE
Guest
Posts: n/a
Just because there is no coolant in the oil/oil in the coolant... don't mean
it's not the head gasket... when I blew up my head gasket on my 94' 22re, it
was doing exactely that, for a long while before it actually went... the
temp would get really hot, and then cool off, then get really hot again...
it would fluctuate... Mine did this for months before the head gasket
finally went..
Ian
"Mike" <mcarpe@frontiernet.net> wrote in message
news:ihZzf.1248$wk5.118@news02.roc.ny...[color=blue]
> news:0eVzf.20294$xk1.471397@news20.bellglobal.com...[color=green]
> > yes top hose gets hot but no symtoms of head gasket, if it is head[/color][/color]
gasket[color=blue][color=green]
> radiator into the resevoir and engine running hot/overheating. Did you[/color]
have[color=blue]
>[/color]
Old 01-21-2006, 09:32 PM   #7 (permalink)
neophyte
Guest
Posts: n/a
Yes same thing, however I have noticed when temp spikes the interior temp
control is at max,when I notice the engine temp increasing I push interior
temp to cool or off (no AC) then the temperature decreases for engine.
have[color=blue]
>[/color]
Old 01-21-2006, 09:34 PM   #8 (permalink)
neophyte
Guest
Posts: n/a
so you wouldsuggest I get that head gasket changed? any idea ofcost?
news:ne9Af.3405$NS6.1552@newssvr30.news.prodigy.com...[color=blue]
> Just because there is no coolant in the oil/oil in the coolant... don't[/color]
mean[color=blue]
> it's not the head gasket... when I blew up my head gasket on my 94' 22re,[/color]
it[color=blue]
> finally went..
> Ian
> news:ihZzf.1248$wk5.118@news02.roc.ny...[color=green]
> > news:0eVzf.20294$xk1.471397@news20.bellglobal.com...[color=darkred]
> gasket[color=green][color=darkred]
> have[color=green]
> >[/color]
>[/color]
Old 01-22-2006, 01:20 PM   #9 (permalink)
EasyE
Guest
Posts: n/a
hahaha.... now that's fucking odd.... when you turn the heater on the
inside of the truck on... It "should" decrease your engine temp since the
heater core is run from your antifreeze, and when you turn your heater on,
your in fact decreasing the temp of your coolant by exchanging the heat from
the coolant into the air that's going to heat your cab.... An old time
"farm" trick is to turn the heater on high if the vehicle is overheating ,
and it will help cool it down.. I think it sounds like a headgasket.... I
don't know how much a repair garage would charge to do it, since nobody but
me has ever touched either of my toys... But to do it yourself would prob
cost you in the neighbor hood of 50 bucks for all the gaskets that should or
have to be replaced at the same time... It's really not a diff job.. Just
make sure your engine is at TDC (top dead center) when you pull the timing
chain, and don't turn the crank until it's back together...
Ian
news:bZCAf.21347$924.325738@news20.bellglobal.com...[color=blue]
> have[color=green]
> >[/color]
>[/color]
Old 01-22-2006, 03:10 PM   #10 (permalink)
neophyte
Guest
Posts: n/a
thanks for all the info everyone, this is an odd one. I'll keep posting when
I know more info.
news:kWQAf.1244$ur7.481@newssvr33.news.prodigy.com...[color=blue]
> your in fact decreasing the temp of your coolant by exchanging the heat[/color]
from[color=blue]
> and it will help cool it down.. I think it sounds like a headgasket....[/color]
I[color=blue]
> don't know how much a repair garage would charge to do it, since nobody[/color]
but[color=blue]
> cost you in the neighbor hood of 50 bucks for all the gaskets that should[/color]
or[color=blue]
> Ian
> news:bZCAf.21347$924.325738@news20.bellglobal.com...[color=green]
> > Yes same thing, however I have noticed when temp spikes the interior[/color][/color]
temp[color=blue][color=green]
> > control is at max,when I notice the engine temp increasing I push[/color][/color]
interior[color=blue][color=green]
> > news:ihZzf.1248$wk5.118@news02.roc.ny...[color=darkred]
> > gasket[color=darkred]
> > > radiator into the resevoir and engine running hot/overheating. Did[/color][/color][/color]
you[color=blue][color=green]
> > have[color=darkred]
> > >[/color]
> >[/color]
>[/color]
Old 01-24-2006, 06:00 AM   #11 (permalink)
PCK
Guest
Posts: n/a
View PCK's Photo Gallery
not so odd, take the thermostat and drill a 3/16" hole in the disc.
this has been covered on Roger`s website and in this newsgroup
news:KsSAf.313$ft2.25077@news20.bellglobal.com...[color=blue]
> when
> I know more info.
> news:kWQAf.1244$ur7.481@newssvr33.news.prodigy.com...[color=green]
>> on,
> from[color=green]
> I[color=green]
> but[color=green]
> or[color=green]
>> Just
>> timing
>> Ian
>> news:bZCAf.21347$924.325738@news20.bellglobal.com...[color=darkred]
> temp[color=green][color=darkred]
> interior[color=green][color=darkred]
>> > gasket
> you[color=green][color=darkred]
>> > have
>> >[/color]
>>[/color]
>[/color]
Old 01-24-2006, 05:30 PM   #12 (permalink)
neophyte
Guest
Posts: n/a
I believe there is a hole in the thermostat(failsafe) I'll check again,
thanx for the tip.
"PCK" <someone@nowhere.com> wrote in message
news:XJidnZNxV6l4i0veRVn-sQ@look.ca...[color=blue]
> news:KsSAf.313$ft2.25077@news20.bellglobal.com...[color=green]
> > when
> > I know more info.
> > news:kWQAf.1244$ur7.481@newssvr33.news.prodigy.com...[color=darkred]
> >> inside of the truck on... It "should" decrease your engine temp since[/color][/color][/color]
the[color=blue][color=green][color=darkred]
> >> on,
> > from[color=darkred]
> >> "farm" trick is to turn the heater on high if the vehicle is[/color][/color][/color]
overheating[color=blue][color=green][color=darkred]
> >> and it will help cool it down.. I think it sounds like a[/color][/color][/color]
headgasket....[color=blue][color=green]
> > I[color=darkred]
> > but[color=darkred]
> >> me has ever touched either of my toys... But to do it yourself would[/color][/color][/color]
prob[color=blue][color=green][color=darkred]
> >> cost you in the neighbor hood of 50 bucks for all the gaskets that[/color][/color][/color]
should[color=blue][color=green]
> > or[color=darkred]
> >> Just
> >> timing
> >> Ian
> > temp[color=darkred]
> > interior[color=darkred]
> >> > temp to cool or off (no AC) then the temperature decreases for[/color][/color][/color]
engine.[color=blue][color=green][color=darkred]
> >> > > > yes top hose gets hot but no symtoms of head gasket, if it is[/color][/color][/color]
head[color=blue][color=green][color=darkred]
> >> > gasket
> >> > > Symptoms of a blown head gasket would be coolant forced out of[/color][/color][/color]
> > you[color=darkred]
> >> > have
> >>[/color]
> >[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
Motor Mount problem and other, please help lazycat Camry & Solara Lounge 4 08-16-2004 09:32 PM
2003 Camry 4cyl - erratic 2000rpm revving with temp indicator light dropping to cold rmorgan210 5th & 6th Generation (2002-2006 & 2007-2011) 2 05-21-2004 10:12 AM
Turn signal problem Chris990 Camry & Solara Lounge 3 04-02-2004 11:06 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
