clutch slipping - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-19-2006, 11:16 AM   #1 (permalink)
Brian Faddis
Guest
Posts: n/a
View Brian Faddis's Photo Gallery
clutch slipping
Hi group...I have a '93 Toyota 4x4 pu that is starting to slip occasionally
in 4th gear. Is there anything I should try before just having the clutch
replaced...like changing gear oil or anything?
Thanks,
Brian
Old 01-19-2006, 11:18 AM   #2 (permalink)
MrFixit469
Guest
Posts: n/a
View MrFixit469's Photo Gallery
Re: clutch slipping
It's a manual trans, right?
Old 01-19-2006, 12:25 PM   #3 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: clutch slipping
Over 90k miles or tow a trailer? If so its the clutch disc --- assuming the
clutch master cylinder had flhid in it. If its empty then slave or master
cylinder could be gone --- but they affect engagement mainly.
"Brian Faddis" <faddisb@msnotes.wustl.edu> wrote in message
news:dqohhg$1ji$1@newsreader.wustl.edu...[color=blue]
> occasionally
> Thanks,
> Brian
>[/color]
Old 01-19-2006, 01:25 PM   #4 (permalink)
Jarhead
Guest
Posts: n/a
View Jarhead's Photo Gallery
Re: clutch slipping
occasionally
clutch
| Thanks,
| Brian
An "Old Timers" way to check the clutch is to gently pull up to, and
nudge, a big tree. Then put your tranny in 3rd gear, rev up the engine a
bit and let out the clutch pedal. It should kill the engine muy pronto.
If it takes a while then you have a worn clutch disc or a defunct
pressure plate, or both. Gears do not slip, clutches do!
Jarhead
Old 01-20-2006, 07:49 PM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: clutch slipping
No. If the clutch is slipping on a 12-year old truck, odds are good that you
need a new clutch.
> occasionally
> Thanks,
> Brian
>[/color]
Old 01-22-2006, 08:21 PM   #6 (permalink)
L
Guest
Posts: n/a
View L's Photo Gallery
Re: clutch slipping
no.
your clutch is done. have it changed or change it and replace:
- pilot bearing
- throwout bearing
- crank seal trans input seal
if the oil pan leaks it can also be tackled now
Matt
Old 01-23-2006, 11:03 AM   #7 (permalink)
MrFixit469
Guest
Posts: n/a
Re: clutch slipping
Wolfgang wrote:[color=blue]
> news:dqohhg$1ji$1@newsreader.wustl.edu...[color=green]
> > occasionally
> > Thanks,
> > Brian
> >[/color][/color]
Old 01-23-2006, 11:06 AM   #8 (permalink)
MrFixit469
Guest
Posts: n/a
Re: clutch slipping
The mileage doesn't matter, I've seen OEM clutches last over 150,000
miles and some fail after 30,000. It's a matter of how their driven.
The original post said nothing about engagement, just slippage when
already in gear.
BB code is Off
Smilies are Off
[IMG] code is Off
Unusual Clutch Slipping Experience Kdx220 1st Generation (1995.5–2004) 0 01-17-2006 09:10 AM
Clutch Slipping aupullma Archived Corolla threads 0 10-19-2005 11:08 AM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
Clutch Slipping Keep Camry & Solara Lounge 7 07-15-2005 07:53 AM
slipping clutch! 91turbo2 MR2 Forum 2 09-27-2003 07:18 PM
