1993 SR5 pickup - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-21-2006, 02:28 AM   #1 (permalink)
isaac
Guest
Posts: n/a
View isaac's Photo Gallery
1993 SR5 pickup
I'm looking at an SR5 in the next couple days, but from what I gather
from the pictures it's sagging a lot in the rear end. How much is a new
set of leaf springs on average? Is it smart to replace the shock when
you replace leaf springs or can you just swap the springs out?
I don't know what motor this truck has in it but it has power steering
and a sunroof, and it has 328,000km on it (about 203,800 miles). It's
pretty high mileage, but don't these things pull 500k km with the right
maintenance?
Thanks for any help,
Isaac
Old 01-21-2006, 03:47 AM   #2 (permalink)
Searcher
Guest
Posts: n/a
View Searcher's Photo Gallery
Re: 1993 SR5 pickup
When replacing the springs, I would at the very least also replace the
shocks, Shocks around here are about 50 US$ per axle. Mine only has 164,000
miles but shes still going strong. I personally know one guy who has over
700,000 on his 1989. He is very adamant about having regular service done to
it. I have had some minor issues but nothing more than normal replacements,
IE. Alternator, (2 times) and a sensor or two. Teh alternator was replaced
once for a bearing issue and once for a failure.
Toyotas are VERY reliable no matter which model you choose
Searcher
Old 01-21-2006, 08:00 AM   #3 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: 1993 SR5 pickup
Or just have a leaf added. If shocks are old looking I'd replace them - new
ones (for non-strut applications) are not expensive. KYBs work fine for me.
"isaac" <isaacsorge@gmail.com> wrote in message
news:1137832115.701326.73740@o13g2000cwo.googlegroups.com...[color=blue]
> maintenance?
> Isaac
>[/color]
Old 01-21-2006, 11:16 AM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
Re: 1993 SR5 pickup
Ouch - are CAD only worth .5USD? Its worth maybe $1500 USD --- less if rust
is perforated the metal. I'd take a serious look at the frame for rust.
Worth maybe $500 if frame is bad (for parts).
news:1137868397.994112.257230@g43g2000cwa.googlegroups.com...[color=blue]
> Well, I went out to take a look at it and take it for a drive. It's the
> V6 engine with an auto transmission (bad combo, I know). The body's in
> alright shape, a little rust in the wheelwells and around the gas cap,
> but nothing major. Turns out the sagging shocks was just an odd angle
> in the photograph cause in person they look perfectly normal.
> The exhaust is broken where the header attaches to the cat. He says
> he's going to try to get the broken section replaced before he sells
> it. Obviously it's very loud and when trying to make it up a pretty
> easy hill it was lugging pretty hard, almost as if it was hesitating,
> and the acceleration on a flat was miserable. Is this because of the
> auto transmission or is it due to the lack of backpressure in the
> exhaust system?
> I'm told him if he gets the pipe fixed I'd be seriously interested, as
> the price is right ($3500CAD asking price, I'll offer $3000) (around
> here 88-89s go for 5 to 6 grand easily). Am I right in assuming the
> cause of the lacklustre performance is probably the broken pipe?
> Also it needs an ebrake cable - are these expensive or hard to install?
> I'll need a shop manual first thing.
>[/color]
Old 01-21-2006, 12:33 PM   #5 (permalink)
isaac
Guest
Posts: n/a
Re: 1993 SR5 pickup
exhaust system?
Old 01-22-2006, 03:13 AM   #6 (permalink)
Eddie
Guest
Posts: n/a
View Eddie's Photo Gallery
Re: 1993 SR5 pickup
The broken exhaust can affect the preformance, but the 3.0L is a dog of
an engine and the auto tranny will make it even worse. I would save up
for a stick.
With around 200k miles on it, you are comming up to the point that things
are starting to wear out. Alternator, PS Pump, AC pump, etc.. will all
most likly have to be replaced within the next 100k miles, if they have
not been by now. Go over it real close and inspect everything.
I am guessing its about time for a timing belt change. And check the
dealers for recalls on it. You may get some work done for free.
The e-brake cable is not bad. The factory shop manuals will help out
greatly if you plan to do any work yourself.
n Sat, 21 Jan 2006 10:33:18 -0800, isaac wrote:
[color=blue]
> but nothing major. Turns out the sagging shocks was just an odd angle in
> The exhaust is broken where the header attaches to the cat. He says he's
> going to try to get the broken section replaced before he sells it.
> Obviously it's very loud and when trying to make it up a pretty easy
> hill it was lugging pretty hard, almost as if it was hesitating, and the
> acceleration on a flat was miserable. Is this because of the auto
> transmission or is it due to the lack of backpressure in the exhaust
> system?
> I'll need a shop manual first thing.[/color]
Old 01-22-2006, 12:40 PM   #7 (permalink)
isaac
Guest
Posts: n/a
Re: 1993 SR5 pickup
The frame was clean; the truck has been undercoated once a year its
entire life.
Regardless I've decided I don't want an automatic, and I can't afford
to run a V6, so I'm saving my money and waiting for a clean 5 speed
22RE.
Thanks for all the help guys, I'll be back when I find my four banger
Cheers,
Isaac
BB code is Off
Smilies are Off
[IMG] code is Off
What is the length of bed on a 1992 SR5 Pickup 4 x 4? 4x4_Babe 89-95 Toyota Pickup/Hilux 3 10-05-2005 09:30 PM
1993 Pickup Wheels - Tacoma/Pickup Compatibility brehry 89-95 Toyota Pickup/Hilux 3 09-23-2005 12:30 PM
22RE: 1989 4runner -> 1993 Pickup lawlopez 89-95 Toyota Pickup/Hilux 3 11-23-2004 02:29 AM
