06 Tacoma Comments/Advice - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-21-2006, 03:45 PM   #1 (permalink)
John Halverson
Guest
Posts: n/a
View John Halverson's Photo Gallery
I'm in the market for an 06 Tacoma. I'm looking at the V6 with manual
transmission and the TRD offroad package. I'd like any comments,
suggestions, and advice you all might have
I live in the Sierras (CA) so I'll be seeing plenty of snow etc. My
hobbys (and somtimes work) take me off pavement frequently but I don't
'4x4' as a hobby per se.
Anyone out there with an 05 orr 06 setup like the above, I'd like to
hear your impressions and advice.
Specific questions:
How does the plastic{!} bed hold up? I 'm a little suspicious
of that.
How does Toyota's locking diff. work? Clutch?, Fluid?, or
(I hope) a solid mechanical connection between the axles?
Has anyone mounted Hella Rallye 4000 Compact driving lights?
Is there enough room on the stock front bumper for them?
Appreciate the feed back, thanks.
Old 01-21-2006, 05:29 PM   #2 (permalink)
Bonehenge
Guest
Posts: n/a
View Bonehenge's Photo Gallery
Re: 06 Tacoma Comments/Advice
On Sat, 21 Jan 2006 21:45:18 GMT, John Halverson
<jh1007679@earthlink.net> wrote:
[color=blue]
> of that.[/color]
My '05's been great. I had a 300 lb. cast iron sander get loose in
the bed and slam the side hard enough to move the truck. The only
damage is a dime-sized indentation, with a very tiny tear. This would
have put a nasty, rusty dent in a steel bed. The impact cracked the
sander. I've now seen a temperature range of 9F to 102F, and the bed
dosen't seem to care.
You CAN scratch the bed, but A.) IT'S A TRUCK, and B.) Steel would
rust if scratched, and paint scratches too! I think of it as having a
bed liner included without the steel weight, and not much to rust. The
bed rear corners are still steel behind the taillights, to support the
bed rail.
I've drilled it for additional tie downs and have been very happy with
the knowledge that I'm not encouraging rust. I read a lot of forums
and can honestly say that I haven't seen bed complaints.
The rail / tie down system is outstanding.
[color=blue]
> (I hope) a solid mechanical connection between the axles?[/color]
I'm not sure, but mine locks well enough to make turning difficult in
mud and deep snow. <G> The truck just wants to push straight ahead.
4WD Low and the turning circle are OUTSTANDING in the Tacoma, and my
other car is a Wrangler Sport! My truck is a TRD Access Cab, the 4
door / long bed is longer, so the turn will be as well.
The clutch cancel switch is actually very handy, as well. It took me
a month or two to remember 6th gear. I drove some highway miles in
5th.
The only real complaint I hear is tailgate strength. Some folks have
done things like drive down a forest road at a decent clip with a dirt
bike centered on the lowered tailgate, which bent it. I'm 240 pounds,
and have stood on it with no ill effects, but I remove it to get my
500 pound mower up there. If you really need a strong gate, I'd check
into having a local truck body guy replace the plastic face with
diamond plate. On the other hand, the gate is easy to remove and
carry so it's easily out of the way, if necessary.
I've averaged about 17 MPG over 6600 miles, on Northeastern USA
emission control blend gas, but I tow a utility trailer, tend to do
75-80 on the highway, and accelerate with spirit. I'm happy with
that, since Toyota sez' 16-20 MPG on the window. The first 2000 or so
miles never got over 15.5 MPG. I switched to Mobil 1 @ 5000 miles.
I'm installed a rubber bed mat, black Toyota running boards, and a
Toyota air deflector to prevent hood paint chips. I highly recommend
the mat. The plastic is a bit slippery so the rubber keeps things in
place. Carrying something light, like insulation? The mat is heavy
enough to be tossed OVER the load, securing it in the bed.
I've had several Toyotas and many vehicles, I truly love this truck.
Under the hood, check out the stainless steel headers, remote oil
filter with drain hole, and Toyota's typical anodized bolts, O-rings,
and nicely finished parts. I do my own maintenance, so I really
appreciate the thought that went into typical maintenance access.
Have fun, it's a great truck and everything I'd expect from Toyota!
Old 01-21-2006, 11:36 PM   #3 (permalink)
John Halverson
Guest
Posts: n/a
>My '05's been great. I had a 300 lb. cast iron sander get loose in[color=blue]
>dosen't seem to care.[/color]
Wheew 300 lbs?! Congratulations you made it! Did the truck help?
[color=blue]
>The rail / tie down system is outstanding.[/color]
It looks good, but I'm glad to hear from folks with experience that it
works.[color=blue]
>[color=green]
>mud and deep snow. <G> The truck just wants to push straight ahead.[/color]
That works for me![color=blue]
>5th.
>Have fun, it's a great truck and everything I'd expect from Toyota![/color]
This is a quick reply, I'm going to to read you post in depth
tomorrow. Maybe I'll have more comments.
Thanks Bro'
Old 01-22-2006, 10:24 AM   #4 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
"John Halverson" <jh1007679@earthlink.net> wrote in message
news:am85t1dqlsde4kai4qcgu0nmrr9bf9p458@4ax.com...[color=blue]
> transmission and the TRD offroad package. I'd like any comments,[/color]
COMMENTS
The wheel openings are butt ugly.
[color=blue]
> Specific questions:
> of that.
> Appreciate the feed back, thanks.[/color]
Old 01-23-2006, 10:38 AM   #5 (permalink)
M.Paul
Guest
Posts: n/a
View M.Paul's Photo Gallery
Here are my comments posted last Wednesday...
One month with a 2006 prerunner and so far so good. The off road package
makes the ride very rough on the hwy, so I wouldn't recommend getting that
package for a commute vehicle. One possible regret is that I got the 4.0
with with a manual transmission. I'm thinking that I should have got the
auto trans. All of my previous cars have been stick and I enjoy shifting.
At first I thought that I would eventually get used to it, but
the more that I drive it, the more that I think the V6/manual is not a good
combination. Anybody else with a V6 and manual trans? If yes, do you start
in 2nd? 1st seems awefully low - I can hardly drive 10 feet before needing
to shift into 2nd.
Also, Toyota still does not offer a tailgate lock for the 05/06 models and
considering
how easily it comes off I hope they offer one soon.
Also as far as the composite bed...
I like it. It saves me from having to buy a bedliner. The moveable
tie-downs work great!
The downside of the composite bed is that while it's black in color,
scratches are very light
in color - almost white - highlighting each and every scratch. The
compartments in the bed
might be handy places to store stuff, but they will probably need to be
taped off if hauling
loose material like sand or gravel. And what is the purpose of the open
compartments directly
above the wheel wells?
Overall it's a great truck. I like driving it and it's design seems to be
thought-out well.
> Specific questions:
> of that.
BB code is Off
Smilies are Off
[IMG] code is Off
Body Lift for 06 tacoma dbl cab 4x2 rickinAZ 2nd Generation (2005+) 3 08-27-2008 01:57 PM
06 Tacoma - 4x2, I4 access - has dash rattle... danamericandan 2nd Generation (2005+) 13 12-07-2005 01:39 AM
06 Tacoma cansv 2nd Generation (2005+) 10 10-06-2005 12:48 PM
Weld EVO "Cheyenne 6" wheels on an '05 or '06 Tacoma?? 57HotrodVW 2nd Generation (2005+) 8 09-26-2005 04:24 PM
