92 4Runner lack of power - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-24-2006, 03:04 PM   #1 (permalink)
Mudduck
Guest
Posts: n/a
View Mudduck's Photo Gallery
I changed spark-plugs,cap,rotor,air-filter,cat,muffler,tail-pipe.and set
time.Some power in 1st thru 3rd less in 4th
none in 5th gear Any idea Thanks
Old 01-24-2006, 07:57 PM   #2 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: 92 4Runner lack of power
22RE or 3.0 V6? Oversize tires? Compression? Injectors calibrated/clean?
Miles?
"Mudduck" <teammoralesbb9@yahoo.com> wrote in message
news:e311dfd62a28e87c66c38e2b2e66fe91@localhost.talkaboutautos.com...[color=blue]
>[/color]
Old 01-25-2006, 03:10 AM   #3 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
>[/color]
How did you set ya timming? Did you bridge out the shorting terminals like
in the book or just grab a timmign light and away you went?
I set mine by ear last time as the light was playing up. Got it checked by
mechanic a month later and it was perfect. I know, I know lucky guess right.
Have you checked your compression? Are you using water? Is there bubbles
comming up through the radiator when the caps off? Is there any blowback out
the oil filler cap? Are the plugs correct? Correct gap?
Old 01-25-2006, 12:15 PM   #4 (permalink)
Mudduck
Guest
Posts: n/a
Sorry its a 3.0 V6, 32"tires, Compression ok,110psi highest 105psi lowest.
157xxx miles.ran great until now.I wil check injectors today. thanks
Old 01-26-2006, 12:22 PM   #5 (permalink)
Eddie
Guest
Posts: n/a
View Eddie's Photo Gallery
Who says 105-110 psi compression is OK? It should be around 170psi.
Check your compression tester. It's that or something is very wrong with
that engine.
On Wed, 25 Jan 2006 10:15:08 -0800, Mudduck wrote:
[color=blue]
> lowest. 157xxx miles.ran great until now.I wil check injectors today.
> thanks[/color]
Old 01-26-2006, 01:32 PM   #6 (permalink)
MrFixit469
Guest
Posts: n/a
View MrFixit469's Photo Gallery
The compression reading just shows there is some engine wear, normal
for an engine with 157,000 miles! The thing to look for is one cylinder
to be drastically different from the others, which there isn't. The
compression is OK! Look somewhere else. Bad spark plugs, plug wires,
distributor cap. Yes, it's possible to buy a bad new spark plug, it
only needs to be dropped once to crack the insulator and cause an
ignition short. Have you had the igniter or ignition coil checked? Most
parts places will check these for free.
Old 01-27-2006, 01:08 AM   #7 (permalink)
Eddie
Guest
Posts: n/a
Some engine wear? A 60psi (170 down to 110) is a ton of wear. At around
90 psi it's gets real hard to get gas to burn.
If the engine is in fact at around 110 psi compression, then the rings or
valves are shot. I am really questioning if the compression tester is bad
since all cylinders are around the same level. Normally, you will see one
cylinder go fist and loose compression.
And 110psi is not normal for an engine with 157k miles unless it's been
run without an air cleaner. I have 337k on my 3L engine and the compression
is around 160 psi.
I suggest Mudduck have a dealer to a second compression check.
On Thu, 26 Jan 2006 11:32:25 -0800, MrFixit469 wrote:
[color=blue]
> The compression reading just shows there is some engine wear, normal for
> an engine with 157,000 miles! The thing to look for is one cylinder to
> distributor cap. Yes, it's possible to buy a bad new spark plug, it only
> needs to be dropped once to crack the insulator and cause an ignition
> short. Have you had the igniter or ignition coil checked? Most parts
> places will check these for free.[/color]
Old 02-02-2006, 06:08 PM   #8 (permalink)
ToddWiedeman
Guest
Posts: n/a
View ToddWiedeman's Photo Gallery
I was going through the same thing, and replaced plugs,cap,rotor,pcv
and then finally a new fuel filter helped
BB code is Off
Smilies are Off
[IMG] code is Off
problems removing power steering pulley (91 4runner) gonzo 4Runner Lounge 4 01-30-2011 04:50 AM
Disconnecting '92 4Runner Alarm daved 4Runner Lounge 3 03-03-2007 02:15 PM
92 4Runner parts ggiroux 4Runner Lounge 0 12-17-2005 03:37 PM
How Would I Be Able To Get The Most Power Out Of My Amp? Vato Loco Audio, Video, and Security - Tech 6 10-26-2004 02:22 PM
