Heater wont turn off - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-25-2006, 03:50 PM   #1 (permalink)
collector1974@msn.com
Guest
Posts: n/a
View collector1974@msn.com's Photo Gallery
Hi!
I have a 89 toyota 2.4L EFI and the heater wont turn off. It is always
blowing hot air (the fan control does work), whehter you turn it to
cold or hot. Any ideas???
Old 01-25-2006, 08:51 PM   #2 (permalink)
Jarhead
Guest
Posts: n/a
View Jarhead's Photo Gallery
Re: Heater wont turn off
<collector1974@msn.com> wrote in message
news:1138225851.993432.34420@g44g2000cwa.googlegroups.com...
| Hi!
always
If it is the same set up as my '87 there is a valve high on the firewall
about in the middle. It has a heater hose in and out. It has a lever
controlled by a music wire cable from your heater quadrant on the dash.
The valve may be frozen, the cable frozen in its sheath, or the cable
may be broken.
Jarhead
Old 01-26-2006, 12:36 PM   #3 (permalink)
Guest
Posts: n/a
Thanks for the info!! Will try it today!
Old 01-26-2006, 04:23 PM   #4 (permalink)
grinder
Guest
Posts: n/a
View grinder's Photo Gallery
news:1138225851.993432.34420@g44g2000cwa.googlegroups.com...[color=blue]
> Hi!
>[/color]
There is a valve in the engine compartment close to the firewall. You can
manually turn it to either turn the heat on or off. Have someone move the
slide in the cabin and see if the valve is moving. If you are lucky the
wire just came off the valve, less luck: wire came off the slide, bad luck:
wire broken.
In my '90 forerunner I can turn the heat off in the cabin by moving the
slide but cannot turn it on again unless I do it manually at the valve.
Old 01-27-2006, 11:25 AM   #5 (permalink)
Guest
Posts: n/a
Great!! Thank you so much!
Old 02-06-2006, 05:04 PM   #6 (permalink)
Guest
Posts: n/a
the cable just popped loose. I snapped it back into place and it works
fine now. Thank you very much.
Old 02-07-2006, 08:41 AM   #7 (permalink)
Jarhead
Guest
Posts: n/a
news:1139267040.367530.75670@o13g2000cwo.googlegroups.com...
works
You're welcome, glad to help.
Jarhead
BB code is Off
Smilies are Off
[IMG] code is Off
1988 Camry Heater Cycles Between Heat & No Heat lashby 1st & 2nd Generation (1983–1986 & 1987-1991) 30 12-11-2006 02:29 PM
heater problem?? dizrick 89-95 Toyota Pickup/Hilux 1 10-18-2005 05:15 AM
buzzing turn signal DAMON Camry & Solara Lounge 1 03-07-2005 06:05 PM
Why does my heater turn cold after a little while???????? 89_3SFE Celica Forum 1 09-14-2004 01:05 AM
Turn Signal Problem pinoy Celica Forum 0 10-13-2002 09:57 PM
