Towing 5000lbs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-29-2006, 10:35 AM   #1 (permalink)
Ribbet4
Guest
Posts: n/a
View Ribbet4's Photo Gallery
Towing 5000lbs
I own a 2000 V-8 Tundra. I know it is rated at towing over 7000lbs but was
wondering what some of the larger things being towed by people in this group
were and how well they did. I am close to purchasing a 5000lb dry weight
travel trailer and was wondering if I would lag too much up hills and so
forth.
Old 01-30-2006, 06:16 PM   #2 (permalink)
Dan
Guest
Posts: n/a
View Dan's Photo Gallery
Re: Towing 5000lbs
I have a trailer that weighs about 1500lb and I have loaded it with 2000lb.
I was able to
easily maintain 75 to 80 mph up all hills with that combination and if I
take it easy, the
mileage does not go down much. This would not have the wind drag you would
have with
your travel trailer. To be honest, there was a LOT of power to spare. I
tried this same
load with a F-150 and a 5.0L and it was so under power it was dangerous. I
also went down
to 8 or 9 mpg with JUST the trailer on my Ford. Never mind that it also
took out 3 of the
u-joints!
In short, I would not hesitate to pull 5000lb with my truck even up all the
hills.
"Ribbet4" <ribbet4@cox.net> wrote in message
news:C86Df.80893$4l5.26011@dukeread05...[color=blue]
>group were and how well they did. I am close to purchasing a 5000lb dry
>weight travel trailer and was wondering if I would lag too much up hills
>and so forth.
>[/color]
Old 01-30-2006, 07:55 PM   #3 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: Towing 5000lbs
I tow a 25' light TT with my 03 V6 4L 4Rnr with no problem. Weight is
probably 4500# wet. I have a weight distribution hitch with antisway and,
of course, electric brakes on the trailer. Have not attempted to tow it in
the mountains though.
>and so forth.
>[/color]
Old 02-01-2006, 06:55 PM   #4 (permalink)
Beach Bum
Guest
Posts: n/a
View Beach Bum's Photo Gallery
Re: Towing 5000lbs
I have a 2000 Tundra w v-8 and tow a 31 foot 'light' TT that weighs
proly 6200 lbs fully loaded. On straight level roads, no problems.
On hills it does struggle a bit. The trailer has a hitch weight of 580
lbs (my hitch has the weight distribution and sway bars etc etc) and it
does cause a fair amount of sag and makes the handling a little
squirrly at times. To answer your question, I dont think you will have
a problem. Im looking at upgrading the brakes, getting stiffer
springs, and doing an engine chip upgrade along with headers and a cat
back exhaust - but that is for my situation, which is traveling almost
every weekend. Give it a go, should be fine
Old 02-04-2006, 10:24 AM   #5 (permalink)
Wolfgang
Guest
Posts: n/a
Re: Towing 5000lbs
Another consideration is to get a 5th wheel trailer vice a tow TT. They are
easier to tow and maneuver.
>and so forth.
>[/color]
Old 02-19-2006, 08:32 AM   #6 (permalink)
Ribbet4
Guest
Posts: n/a
Re: Towing 5000lbs
What hitch are you using? Dual cam or friction control anti sway?
"Wolfgang" <NOwolfXgang_dieterSPAM@NOXcox.net> wrote in message
news:wvzDf.6182$2o5.2868@dukeread11...[color=blue]
> news:C86Df.80893$4l5.26011@dukeread05...[color=green]
>>was wondering what some of the larger things being towed by people in this
>>and so forth.
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
towing with a Sienna bafuller 1st Generation (1998-2003) 7 01-13-2010 11:56 AM
Towing questions... mcgrupp 2nd Generation (2005+) 13 01-04-2006 08:32 PM
Bumper Towing ? Bisch 2nd Generation (2005+) 4 08-26-2005 08:21 PM
2005 Tacoma Towing Question greystoke 2nd Generation (2005+) 2 08-07-2005 06:28 PM
