V8 Tunndra oil filter mess - any tips? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 01-31-2006, 03:12 PM   #1 (permalink)
N Williamson
Guest
Posts: n/a
View N Williamson's Photo Gallery
What a mess! Thought placing a rag (old tee shirt) under the filter
area would catch any residual. NOT! It simply ran off onto the skid
plate and onto the garage floor.
Do you folks remove the plate for a filter change?
If yes, any snafu's to removing the plate or reinstalling it?
If no, any tips for a tidy'er filter change will be greatly appreciated.
Thanks,
Nate
Why is it all the sensors seeking intelligent
life are pointed away from earth?
Old 01-31-2006, 04:30 PM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: V8 Tunndra oil filter mess - any tips?
N Williamson wrote:[color=blue]
> appreciated.
> Thanks,
> Nate[/color]
My Tundra doesn't have a skid plate but the filter is still hard to get to
and makes a mess. I bought a cheap, flexible plastic cutting board which I
put under the filter and the oil is directed over the crossmember and into
the pan. I had to trim a corner off to get it at the angle I need. I thought
about using a couple pieces of PVC pipe and a 45 deg angle and cutting a
notch at the end of the pipe where it would fit under the filter.
Another tip I got from this ng was to break filter loose but don't loosen it
enough for oil to drain, put a plastic bag over filter and then remove. The
bag is supposed to catch oil, wasn't a total success for me but was better
than nothing.
davidj92
Old 01-31-2006, 09:51 PM   #3 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
removing the skid plate is the way to go. Should be three 12mm bolts on the
front of it and two on rear.
Old 02-01-2006, 08:44 AM   #4 (permalink)
Victor D. Ulmer
Guest
Posts: n/a
View Victor D. Ulmer's Photo Gallery
Instead of using a plastic bag, consider using a flexible plastic container,
such as those used for selling cottage cheese, which is slightly larger than
the oil filter. If the oil filter is mounted vertically (as it is on my
Toyota Tacoma), the sides of the container are tall enough to extend above
where the base of the filter meets the filter base on the engine. The
plastic container is flexible enough, so that the sides of it can be pressed
against the sides of the partly loosened filter, and the filter can then be
turned and allowed to slip into the container, with the escaping oil. This
works for me.
Vic Ulmer
"davidj92" <davidj92REMOVE@sigecom.net> wrote in message
news:rJednXEG3tKNeELeRVn-tg@sigecom.net...[color=blue]
>N Williamson wrote:[color=green]
>> appreciated.
>> Thanks,
>> Nate[/color]
> thought about using a couple pieces of PVC pipe and a 45 deg angle and
> cutting a notch at the end of the pipe where it would fit under the
> filter.
> it enough for oil to drain, put a plastic bag over filter and then remove.
> The bag is supposed to catch oil, wasn't a total success for me but was
> better than nothing.
> davidj92
>[/color]
Old 02-01-2006, 08:50 AM   #5 (permalink)
N Williamson
Guest
Posts: n/a
In article <rJednXEG3tKNeELeRVn-tg@sigecom.net>,
"davidj92" <davidj92REMOVE@sigecom.net> wrote:
[color=blue]
> > appreciated.
> > Thanks,
> > Nate[/color]
> than nothing.
> davidj92[/color]
I just might try that bag trick. Thank you.
Nate
Old 02-01-2006, 08:51 AM   #6 (permalink)
N Williamson
Guest
Posts: n/a
In article
<a1310c43b8fd0c85b963c530d83a416d@localhost.talkaboutautos.com>,
"qslim" <Suckers@suckersdotcom> wrote:
[color=blue]
> front of it and two on rear.[/color]
I'll look into this next time. Sure would simplify keeping it a clean
operation. Thanks.
Nate
Old 02-01-2006, 04:14 PM   #7 (permalink)
davidj92
Guest
Posts: n/a
Victor D. Ulmer wrote:[color=blue]
> container, such as those used for selling cottage cheese, which is[/color]
good tip, thanks.
davidj92
Old 02-01-2006, 11:24 PM   #8 (permalink)
Skip
Guest
Posts: n/a
View Skip's Photo Gallery
On Wed, 1 Feb 2006 16:14:27 -0600, "davidj92"
[color=blue]
>Victor D. Ulmer wrote:[color=green]
>good tip, thanks.
>davidj92
>[/color]
I take the skid plate off my Tundra with an air impact wrench and put
it back with an air ratchet driver. Zip, zip, it comes off and goes
back on in no time. I use a gallon jug that milk comes in with the
top cut off. Works great.
Skip
BB code is Off
Smilies are Off
[IMG] code is Off
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
Offroding and trashed oil filter. Need advice twoblackbelts Hardcore Tech and Competition 13 04-03-2005 02:34 PM
Solara 5S-FE oil filter removing. (Dumb) SolaraTRD Solara 20 01-24-2005 11:54 AM
Oil Filter FrankXT86 Camry & Solara Lounge 4 11-10-2004 08:31 PM
Oil filter relocation and oil coolers Meisner Hardcore Tech and Competition 0 04-21-2002 03:44 PM
