replacing head gasket concerns - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 02-01-2006, 08:14 PM   #1 (permalink)
yippie
Guest
Posts: n/a
View yippie's Photo Gallery
Hi all, I'm a proud owner of a 94 toyota pickup with the 22re motor. My
concern regards the head. To make a long story short, I was orignally
replacing the timing chain and gears with one from lc engineering and
accidentally dropped my head on the cardboard I put on the ground. My
fingers slip from some of the oil that was on the hooks on the head. It
was about a 6-7 inch drop, one side falling faster than the other. I
bolted it back on the block with the new head gasket and wondering what
I should be looking for in terms of damage. Also when turning the
crank, is it supposed to be tough to turn at one point of the cycle?
The cam seems to turn easy though. I rather take off the head and get
another gasket rather than unbolt everything. Thanks!
Old 02-01-2006, 09:52 PM   #2 (permalink)
EasyE
Guest
Posts: n/a
View EasyE's Photo Gallery
Re: replacing head gasket concerns
It's not likely that a 6-7 inch drop onto cardboard would cause any damage
to the head that would result in NO compression... Are your spark plugs
in?? I know... sounds like an unbelievabably obvious question... but I've
been there done that.. if the head gasket is new, and the head was bolted
down properly, to the correct torque specs, then it should have
compression... If you damaged the head, then it is very unlikely you'll be
able to tell what exactely it is, unless of course it is obvious.. there
could be hairline cracks that the naked eye couldn't spot.. since it is all
bolted together... try turning it over by means of the starter and doing a
compression check... then you'll know for sure...
"yippie" <yip.sun@gmail.com> wrote in message
news:1138846466.055684.6460@f14g2000cwb.googlegroups.com...[color=blue]
>[/color]
Old 02-02-2006, 08:40 AM   #3 (permalink)
yippie
Guest
Posts: n/a
thanks for the reply. It was worrying me this whole time that the head
was going to be damaged. Reading all the things that happened on the
board made me nervous. Either way though, I'm glad I did it and spotted
the "usual" plastic guide being cheweed away. Scary stuff there.
Old 02-03-2006, 01:32 PM   #4 (permalink)
ww
Guest
Posts: n/a
View ww's Photo Gallery
When turning the crank by hand, there will it a hard spot when two of
the pistons start to compress the intake air-(fuel).
Old 02-03-2006, 01:43 PM   #5 (permalink)
Joe
Guest
Posts: n/a
View Joe's Photo Gallery
The only thing to check would be to check if you have bent any valves that
would have been open if they protrude past the head face, Easy enough to
check place head chamber up and valves closed and fill chamber with
penetrating oil (WD40 ect.) and it shouldn't leak away if the valves are
sealing.
Joe
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
head gasket ladydanyell Camry & Solara Lounge 10 09-27-2004 05:45 PM
