Power Steering Pump Blues, Newbie Style - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 02-03-2006, 05:59 PM   #1 (permalink)
rigger
Guest
Posts: n/a
View rigger's Photo Gallery
Hi folks. I'm hoping someone can tell me their solution to my problem.
I had my '94 4Runner (V6) in for the relay rod recall and the service
writer said they could fix a leak in my steering pump for $382.12 + tax
(for rebuilding the pump). Instead I invested $40.00 and bought a
rebuild kit to install today. I drained the reservoir and moved a hose
out of the way but then ran into the problem.
How the heck do you break loose the nut? The pulley is solid and I've
tried wedging a shop rag between the belt and pulley but it just won't
break loose. I'm even wondering if I'm going in the right direction
(cc for a right hand thread?).
Has anyone had this problem? And maybe a solution?
Thanks for ANY ideas anyone may have.
dennis
in nca
Old 02-03-2006, 06:14 PM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: Power Steering Pump Blues, Newbie Style
rigger wrote:[color=blue]
> problem.
> tax (for rebuilding the pump). Instead I invested $40.00 and bought a
> hose out of the way but then ran into the problem.
>[/color]
Dennis,
The pulley's turning direction when operating, either CW or CCW, should
drive the pump shaft, thereby tightening it it. To remove you would turn the
pulley in the opposite direction. Sometimes this type of connection will get
so tight it takes a shock to release it, like getting all the tension out in
the direction you need to go and hitting the end wrench with a hammer.
HTH,
davidj92
Old 02-03-2006, 06:25 PM   #3 (permalink)
rigger
Guest
Posts: n/a
[color=blue]
> Dennis,
> HTH,
> davidj92[/color]
Thanks David.
I was giving some thought to putting on more torque but was very
hesitant about doing something I'd be sorry for. Been there before.
dennis
in nca
BB code is Off
Smilies are Off
[IMG] code is Off
how to disable power steering pump? nadir Celica Forum 14 03-07-2009 07:05 AM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
replacing 3VZ-FE power steering pump mazdaverx7 Camry & Solara Lounge 1 09-15-2005 10:33 AM
faulty power steering 89 GT rutuger85 Celica Forum 8 08-04-2005 09:33 PM
