Loss of power and slipping out of first - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 02-05-2006, 03:52 PM   #1 (permalink)
Jen424
Guest
Posts: n/a
View Jen424's Photo Gallery
My 90 4x4 truck makes a loud breathing noise when Im at a stop. It gets
either stuck in idle or makes an in and out breathing noise.I changed the
plugs, gas filter, PBC valve and put some good lub in with the oil.My
truck is weak and has no power and shakes a lot sometimes. I know it
sounds like a piece of junk but I love it and can't part with it,please
help me save him.
Old 02-06-2006, 10:51 AM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: Loss of power and slipping out of first
Jen424 wrote:[color=blue]
> gets either stuck in idle or makes an in and out breathing noise.I
> changed the plugs, gas filter, PBC valve and put some good lub in
> with the oil.My truck is weak and has no power and shakes a lot
> sometimes. I know it sounds like a piece of junk but I love it and
> can't part with it,please help me save him.[/color]
First it sounds like you need to check for vacuum leaks, suspect that's a
sure problem. IAC could be dirty and/or sticking, not sure on specifics,
maybe someone else will post procedure or you can google for it, lot's of
posts on that subject. Again, not positive on the specifics but others have
posted that Toy's coil is inside the distibutor cap and that oil leaking
around the o-ring can cause shorts and spark jump. You can goodle this for
more specific info but, first fix is to clean thoroughly inside the cap and
the coil with denatured alcohol. If really oily then you may have to r&r the
o-ring. If spark jumping or tracking has damaged the inside of the cap or
terminals then you will have to r&r the cap (probably a good idea to do this
with the basic tune-up anyway).
Staying with the basics, did you use OEM plugs or the cheapest? Pull plug(s)
to check if they are fouled. Are the plug wires in good shape? You need to
resistance check them to be sure. Rule of thumb is appx 3-5K ohms per foot.
Check for leakage by watching plug wires at night with engine running. Any
leakage should show as sparks or glow around wires. Did you cross any wires
where one is laying on top of the other or damage a wire when pulling them
off?
davidj92
Old 02-06-2006, 11:26 AM   #3 (permalink)
MrFixit469
Guest
Posts: n/a
View MrFixit469's Photo Gallery
Before you fix anything else, FIX THE VACUUMN LEAK! Take a 3' piece of
vacuumn hose, stick one end in an ear and move the other end around
your warmed up running engine. Just be careful around moving parts.
When you find the leak, you'll know it. It'll be a loud hissing sound.
BB code is Off
Smilies are Off
[IMG] code is Off
is my transmission slipping? elvasoshexai Camry & Solara Lounge 4 12-08-2005 06:13 PM
How can i tell my if my clutch is slipping or going bad? wkinnear 89-95 Toyota Pickup/Hilux 2 10-22-2005 10:00 PM
2006 Lexus LX 470 rolla-XRS Toyota News 8 06-01-2005 03:12 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
