Re: Where is the Fuel Filter located
On 6 Feb 2006 15:00:07 -0800, "collector1974@msn.com"
<collector1974@msn.com> wrote:
[color=blue]
>1989 Toyota 2.4L EFI 4x4
>Will someone please tell me where the fuel filter is located? I looked
>on the passenger side under the truck and followed the fuel line out of
>the fuel tank.. I don't see it.[/color]
There's a "sock" pre-filter on the pickup inside the tank (that you
have to drop the tank to change) and there is a pressurized filter on
the fuel line to the engine - usually tucked next to or inside the
frame rail close to the engine. It's a big metal can.
And unless you've been literally pouring mud into the filler neck
(as in filling up from drums and cans and other contaminated fuel
sources in the Jungle, Desert or Australian Outback) both of the
filters shouldn't need changing for at least 250,000 miles - they have
a lot of dirt capacity. Do the fuel pressure and fuel flow tests
first, it may be a failing fuel pump.
Be very careful with the fuel line flare nuts if you still insist on
changing the filter. They were installed by gorillas at the factory
and the nuts strip out really easy. You must use the proper flare
wrenches, and a backup wrench on the opposing fitting - and it's still
really easy to twist and kink the steel line.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
