2000 4Runner - Towing Popup Camper Questions - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 02-07-2006, 06:25 PM   #1 (permalink)
O.B.
Guest
Posts: n/a
View O.B.'s Photo Gallery
Was planning to use a 2000 V6 2WD 4Runner to haul a 1 ton popup camper
into the mountains. The camper is equipped with electric brakes and the
SUV has an electric brake mechanism installed. Is it okay to haul the
camper as is? Or do I need to invest into the transmission and power
steering fluid coolers?
Old 02-08-2006, 01:24 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: 2000 4Runner - Towing Popup Camper Questions
On Tue, 07 Feb 2006 18:25:09 -0600, "O.B." <funkjunk@bellsouth.net>
wrote:
[color=blue]
>steering fluid coolers?[/color]
Power steering cooler probably is overkill, though it can't hurt.
But if you have an automatic transmission the added cooler is a must.
You generate a lot more heat in the torque converter while towing, and
if you don't get rid if it you can cook the transmission fast.
If you have a deep-cycle battery in the trailer, you want to add a
charging isolator relay in the truck for the charge line. If you just
link the two batteries, you can end up with both too dead to start the
truck. This is bad.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 02-10-2006, 12:30 AM   #3 (permalink)
Joe
Guest
Posts: n/a
View Joe's Photo Gallery
I agree power steer cooler a bit of overkill but the trans cooler is a must
especially if you are doing any sort of mountain work, just install the
cooler early enough to check for leaks properly .
Joe
"O.B." <funkjunk@bellsouth.net> wrote in message
news:11uiej67jr1q68a@corp.supernews.com...[color=blue]
BB code is Off
Smilies are Off
[IMG] code is Off
2000 4Runner, Remove Factory Stereo? -Oz- Audio, Video, and Security - Tech 1 06-09-2005 12:45 AM
A Truck Camper for My 2000 Tacoma Extended Cab 4x4 LDHunter 1st Generation (1995.5–2004) 2 12-11-2004 01:36 AM
'97 4Runner Limited wiring questions 97Ltd4Runner Audio, Video, and Security - Tech 1 06-22-2004 11:01 PM
1999 Toyota 4Runner Towing Capacity jednastka 4Runner Lounge 1 03-06-2004 10:06 PM
Four Cylinder 4Runner questions .(newbie ) pfbmgd 4Runner Lounge 4 09-18-2003 04:44 AM
