Re: weight distribution and sway bars
On Mon, 20 Feb 2006 12:13:53 -0800, Ken Shelton
<shelton@cablespeed.com> wrote:
[color=blue]
>Ribbet4 wrote:[color=green]
>> What hitch is best for 700# hitch weight travel trailer. With a dual cam
>> anti sway do I have to drill holes in the trailer frame to mount the anti
>> sway?
>>[/color]
>Best is a Hensley Arrow hitch or Pullrite hitch. Both cost a LOT.[/color]
The Hensley Arrow or Pullrite designs are really only needed when
the trailer size and/or weight is severely straining the towing limits
of the towing vehicle - which should lead you to getting a larger tow
vehicle or a smaller trailer rather than a fancy hitch to 'cure' the
problem. That, and people who have to back their trailers into really
restricted spots requiring severe turns.
The Hensley makes a rigid connection between the trailer and hitch
ball (side to side) and move the pivot point under the rear axle.
Works kinds of like a Gooseneck Hitch like you'd find on a farm
trailer, but in reverse tucked under the car. It takes up a lot of
ground clearance room under the car for the drawbar and pivot
hardware, and you need to leave all the pivot zone totally clear -
some cars require major exhaust system mods to get it to fit.
I wouldn't mess with a Hensley unless you REALLY need it.
[color=blue]
>Second best are either the Drawtite/Reese/HiddenHitch dual cam or
>the Equal-i-zer brand hitch.[/color]
These are variations of standardized torsion-bar load leveling
hitches, and they plug into standard square-tongue receivers on the
car. And the special hitch receivers that plug into the car end can
be easily exchanged between cars when you change vehicles, though they
may have to be modified for receiver height and/or mounting angle.
The sway control and/or load leveler torsion-bar coupling arms
either clamp or weld onto the sides of the trailer A-frame extension
that the coupler is welded to.
[color=blue]
>The original model of the dual cam does not require holes in the
>frame, but might require repositioning the battery or propane holder
>to allow for U-bolts over the frame.[/color]
(Gotta run - I think this makes sense - If I missed something in
proofreading I'll fix it later.)
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
