howto replace front parking/marker lite for 94 pickup? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 02-19-2006, 12:52 PM   #1 (permalink)
JeB
Guest
Posts: n/a
View JeB's Photo Gallery
Hi folks -
The right front marker light on my '94 pickup is burned out and i'm
finding myself challenged as to how to replace. The two obvious
screws loosen the entire housing for the unit, but it seems to be
still attached to the front grill. The lens doesn't wont to separate
from the housing. Any thoughts on what I'm doing wrong?
- jim
Old 02-19-2006, 06:20 PM   #2 (permalink)
Pop-N-Fresh
Guest
Posts: n/a
View Pop-N-Fresh's Photo Gallery
Re: howto replace front parking/marker lite for 94 pickup?
pull towards you as hard as you can.... there are 2 pins holding it
in... they look like
pin hole
it should pop out.... dont worry it wont break
JeB wrote:[color=blue]
> Hi folks -
> - jim[/color]
Old 02-19-2006, 10:35 PM   #3 (permalink)
JeB
Guest
Posts: n/a
On 19 Feb 2006 16:20:21 -0800, "Pop-N-Fresh"
<linux.server@charter.net> wrote:
[color=blue]
>pin hole
>[/color]
The pins are holding the lens to the housing or the housing to the
truck body or front grill?
Old 02-19-2006, 11:37 PM   #4 (permalink)
yippie
Guest
Posts: n/a
View yippie's Photo Gallery
the pins are linked to the front grille. I would get something like a
plastic wedge or something and put it between the lamp and the grille
and slowly wedge it apart. Once you get it apart enough so that you can
get your fingertips in, then use your hands to pop it open. Remember to
go slowly with this, the lens is pretty easy to break. Hope that helps
some.
Old 02-19-2006, 11:55 PM   #5 (permalink)
yippie
Guest
Posts: n/a
the pins are linked to the front grille or at least I think I remember
they were linked to the front grille. Regardless though I would get
something like a plastic wedge or something and put it between the lamp
and the grille and slowly wedge it apart. Once you get it apart enough
so that you can get your fingertips in, then use your hands to pop it
open. Remember to go slowly with this, the lens is pretty easy to
break. Hope that helps some.
Old 02-20-2006, 03:36 AM   #6 (permalink)
Pop-N-Fresh
Guest
Posts: n/a
its all metal.... just pull until they pop out of the grill
its really simple and nothing is gonna break
i just yanked the shit outta mine and there fine
yippie wrote:[color=blue]
> break. Hope that helps some.[/color]
Old 02-20-2006, 07:38 AM   #7 (permalink)
EasyE
Guest
Posts: n/a
View EasyE's Photo Gallery
First off.... everything is NOT metal.... The pins themselves are metal, so
you don't have to worry about actually breaking the pins... but everything
around the pins are chrome plated plastic... it's not hard to break either
the grill of the corner light plastic base.... the pins are built into the
base of the corner light, and the pins slip into the grill.... you could
even use a slotted screwdriver to "gently" pry it off, even though the pins
are brass, they are know to corode to a certain extent and can be in there
if they havn't been removed since 1994....
Ian
"Pop-N-Fresh" <linux.server@charter.net> wrote in message
news:1140428164.896494.140710@g14g2000cwa.googlegroups.com...[color=blue]
> yippie wrote:[color=green]
>[/color]
Old 02-20-2006, 06:54 PM   #8 (permalink)
JeB
Guest
Posts: n/a
Ok ... thanx to all for the replies. I'll go give it a tug. The lens
seems to have been peppered with a bunch of rock or something and
has a bunch of small cracks so I'm a bit nervous about this but I do
need to replace the light.
- jb
On Mon, 20 Feb 2006 13:38:42 GMT, "EasyE" <ezeuconn@hotmail.com>
wrote:
[color=blue]
>Ian
>news:1140428164.896494.140710@g14g2000cwa.googlegroups.com...[color=green]
>> yippie wrote:[color=darkred]
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Need front end for a 93 Pickup 2wd dkmulford 89-95 Toyota Pickup/Hilux 1 07-07-2007 12:27 AM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
Directions To Replace Front Brake Pads Passat_guy21 Celica Forum 0 09-26-2003 05:53 PM
Is there a write up on how to replace front axle? jtaylr77 Archived Corolla threads 1 04-02-2003 08:58 PM
