Re: 89 pickup problems
[email]wilfredanderson@gmail.com[/email] wrote:[color=blue]
> My son recently had his 89 v-6 engine overhauled(Late Dec. 2005) and
> about a month ago started getting foam when he removes the engine oil
> filler cap. He is having to replace radiator fluid about every other
> day. No other leakage noticed. Took it back to shop and they said
> engine okay and leakage in heater coil. Not! He has taken it to
> another shop and they tested for carbon monoxide in radiator fluid,
> but was not conclusive. He was told to run engine until head gasket
> blows. Second shop also said repair shops are putting cheap head
> gaskets in and not the new re-designed thicker head gaskets.
> If anyone has information on what is problem, testing procedures,
> cures, I would sure like to know.
> Bill[/color]
If he's getting foam in his oil and losing coolant then I'd say he
definately has either a head gasket or head problem, probably gasket.
Usually if the head is cracked or warped it will pressurize the cooling
system. Is the foam a different color than the oil? Usually when coolant
mixes with oil it will turn a dirty brown color.
davidj92
