Clutch pedal squeeks. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 02-24-2006, 09:22 PM   #1 (permalink)
grinder
Guest
Posts: n/a
View grinder's Photo Gallery
Took my '90 4Runner for recall (steering relay rod). When I got it back I
noticed the clutch pedal squeeks about 2"-3" from the bottom. I can feel
friction at that point. I greased every joint and the two clutch related
switches under the dash.
I cannot trace the linkage once it gets into the engine compartment or under
the truck. I did find some linkage under the truck under the front
passenger seat and greased that up as well (it looks like it might be the
hand break linkage to the rear wheel).
Somewhere back in my mind I ran into this problem before and resolved it.
Unfortunately age (mine) is taking it's toll and I cannot remember what I
did.
Any ideas?
Old 02-25-2006, 12:06 PM   #2 (permalink)
grinder
Guest
Posts: n/a
Re: Clutch pedal squeeks.
"grinder" <seagle@earthlink.invalid> wrote in message
news:UbPLf.631$6I.285@newsread3.news.pas.earthlink.net...[color=blue]
> under the truck. I did find some linkage under the truck under the front
> it. Unfortunately age (mine) is taking it's toll and I cannot remember
> what I did.
> Any ideas?
>[/color]
Took the truck to the garage and the mechanic said the squeeking clutch
pedal is SOP with trucks from about 1988-2001. His 2000 Tundra has the same
problem and evidently Toyota has issued TSBs saying the squeeking is normal.
Old 02-25-2006, 06:18 PM   #3 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Many have the pivot point bracket that the clutch petal swings on crack from
use. It squeaks only until it breaks and you have to have it welded.
news:980Mf.5027$UN.2050@newsread2.news.pas.earthlink.net...[color=blue]
> news:UbPLf.631$6I.285@newsread3.news.pas.earthlink.net...[color=green]
>> I noticed the clutch pedal squeeks about 2"-3" from the bottom. I can
>> feel friction at that point. I greased every joint and the two clutch
>> related switches under the dash.
>> what I did.
>> Any ideas?
>>[/color]
> same problem and evidently Toyota has issued TSBs saying the squeeking is
> normal.
>[/color]
Old 02-25-2006, 06:21 PM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
Did you get a recall letter - or just schedule and take it in? I'm original
owner of a '90 4Rnr --- never moved and haven't gotten a recall notice. Do
they have to realign the front end when they replace the piece? If so is
that under the recall to? I did have the AC evap valve replaced (and the
R12 FREON) under a special service campaign --- FREE. But it was after
taking it in to have AC repaired. I was expecting a $400+ bill - but nada!
> what I did.
> Any ideas?
>[/color]
Old 02-26-2006, 04:59 PM   #5 (permalink)
grinder
Guest
Posts: n/a
"Wolfgang" <NOwolfXgang_dieterSPAM@NOXcox.net> wrote in message
news:3B5Mf.20551$2c4.1919@dukeread11...[color=blue]
> from use. It squeaks only until it breaks and you have to have it welded.
>[/color]
Had that happen already. You can tell when the bracket is weakening because
the clutch will have to be depressed further and further to disengage.
I don't have any such problem.
Old 02-26-2006, 05:00 PM   #6 (permalink)
grinder
Guest
Posts: n/a
news:mE5Mf.20552$2c4.10450@dukeread11...[color=blue]
> Did you get a recall letter - or just schedule and take it in?[/color]
Recall letter.
I'm original[color=blue]
> Do they have to realign the front end when they replace the piece?[/color]
Yes. The dealership allowed 4 hours to do the entire job.
If so is[color=blue]
> that under the recall to?[/color]
Yes.
I did have the AC evap valve replaced (and the[color=blue]
> nada!
>> what I did.
>> Any ideas?
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Clutch Pedal vibration after clutch change 96 Camry blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-08-2006 01:54 AM
Cramped around the clutch pedal Sonny 2nd Generation (2005+) 16 06-07-2005 06:05 PM
Cheap clutch pedal assembly... 97camryman Camry & Solara Lounge 10 02-24-2005 11:51 PM
1990 4Runner Clutch Pedal BROKE wilco333 4Runner Lounge 2 02-13-2005 06:36 PM
Squeeky Clutch pedal. Chris Corolla S Hardcore Tech and Competition 7 07-20-2004 12:45 PM
