Automatic Tranmission hanging - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 02-26-2006, 11:48 PM   #1 (permalink)
yippie
Guest
Posts: n/a
View yippie's Photo Gallery
Hey all, I guess it seems that I'm always having problems, but here's
my scenario now. I replaced the head gasket and the timing chain and
when I put it all back together, my transmission shifts funny. Before I
started the teardown, the transmission shifted as smooth as butter. Now
three weeks later when I got it all done, it hangs on to gears. First
to second gear is smooth. Second to third hangs on, almost redlining
the engine before it shifts. Then third to fourth is the same thing.
Only when I slightly lift does it upshift. Downshifting is immediate. I
replaced the throttle positions sensor, adjusted it, and it still does
the same thing. Any suggestions?
Old 02-27-2006, 05:24 PM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: Automatic Tranmission hanging
yippie wrote:[color=blue]
> I started the teardown, the transmission shifted as smooth as butter.
> Now three weeks later when I got it all done, it hangs on to gears.
> First to second gear is smooth. Second to third hangs on, almost
> redlining the engine before it shifts. Then third to fourth is the
> same thing. Only when I slightly lift does it upshift. Downshifting
> is immediate. I replaced the throttle positions sensor, adjusted it,
> and it still does the same thing. Any suggestions?[/color]
Does the trans have a vacuum modulator? If so check for a damaged or
unconnected vacuum line on the top side of engine.
davidj92
Old 02-27-2006, 05:27 PM   #3 (permalink)
yippie
Guest
Posts: n/a
I believe that it has a vacuum modulator. I just found a vacuum diagram
off the web and going try to see if I connected the vacuum lines wrong.
If not, I'm stumped.
Old 02-28-2006, 10:55 AM   #4 (permalink)
yippie
Guest
Posts: n/a
Found a vacuum hose that was off the VSV and 2 hoses that were in the
wrong place and helped quite a bit. I don't have to lift nearly as
often to get it to upshift, but it's still rough shifting from one gear
to another. BTW, what is a VSV? I see it on the diagram, but I wasn't
sure what it was. Is it a variable speed valve?
Old 02-28-2006, 07:32 PM   #5 (permalink)
davidj92
Guest
Posts: n/a
> gear to another. BTW, what is a VSV? I see it on the diagram, but I
> wasn't sure what it was. Is it a variable speed valve?[/color]
It's a vacuum solonoid valve which controls a vacuum actuator. They are used
on EGR valves, vapors from fuel tank and etc.
It sounds like you've still got a vacuum line on wrong or bad. Do you have a
vacuum gauge to check vacuum and/or hoses?
Old 02-28-2006, 11:54 PM   #6 (permalink)
yippie
Guest
Posts: n/a
heh, the only way that I know is by putting my finger over it and
seeing if it has and suction. I played around with it yesterday, and
it's still pretty much the same going from 2-3rd. 3rd to 4th is much
smoother. If I let it run, it'll go to about 45mph, then upshift kinda
hard from 2nd to 3rd. Not a jerking hard, but harder than before. If I
let go of the gas, it'll upshift around 25mph. 4th gear will not
upshift any sooner than 40mph. even then I'll have to lift slightly to
get it to go. But this truck really pulls though. Going uphill with
partial throttle, steady cruising up at 65mph in 4th. Gun it in 3rd, it
really picks up speed well. No leakage under the transmission either.
I'm going to change out the fluid and filter this weekend, hopefully
some good news before then.
BB code is Off
Smilies are Off
[IMG] code is Off
AUTOMATIC vs. STANDARD sloppybeak Hardcore Tech and Competition 14 01-18-2006 03:24 PM
DEI Alarm and Automatic Headlights cklinh Audio, Video, and Security - Tech 3 07-28-2004 12:20 PM
Got f*cked over by tranmission problems... Tony the Tiger Camry & Solara Lounge 8 05-16-2003 10:20 AM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 10:54 AM
